8mpg, running rich, here are my scantool results
LaureltheQueen
- Spelling Nazi
free5ty1e
Cyrillic, you must mean? You're slipping, Laurel...LaureltheQueen wrote:written in cryllic.
Nico, even with the way I drive, I still get at least 20mpg with city driving. 8mpg is more like the best-case scenario for my GMC with an empty cargo area.
I think she's got a different issue than standard Subaru richness.
-Chris
91SS 4EAT stock, 200k mi
douglas vincent
Its driven by a woman?free5ty1e wrote: I think she's got a different issue than standard Subaru richness.
"ducks"
If you don't get the temp sensor removed before you come down, I will help you if you need it. And if you don't get one from Nick, I will get another one from U-pull-it next time I am out there.
Gee, you don't think that because you have a Piggyback that it might make your fuel maps different?!?!?!NICO I WRX U wrote:i just want to add something about this running rich problem everyone is haveing on ej22t motors.
i owned a ej22t motor for a very very long time 14 years 850,000kms half a million miles. i just put dohc heads on my block which everyone might now, the fuel consumption with bigger heads whent down some much i forget when was the last time i whent to the gas station.
with the sohc heads i was useing twice the fuel it was like a pig, with the new heads on the consumption whent down alot.
i have no "specs" for everyone to compare, but i can tell very much bye dialy driving.
its normal for this stock ej22t run so rich
my emanage is stock, i have not done anything to it. i am also running 550cc injectors and my car still runs very fuel efficent.
LaureltheQueen
- Spelling Nazi
bahahaha, I think I fixed it. My friend's girlfriend has been borrowing my car every now and again while he's doing work on her nissan, and she's been filling the gas tank. I filled it the other night, and no sucky noise happened when I opened the cap. I think she wasn't tightening it properly, thus causing it to evaporate at a higher rate. lol
It's since gone back up to about 12mpg
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
free5ty1e
Well, looks like you found one factor at least... 12mpg is still pretty low unless you ride around constantly at WOT.
Do you smell gas when walking around the car after a drive? Or before a drive? (do you walk around your car before you drive it?)
My gas tank had a leak around the filler area, would leak out when I had more than 3/4 of a tank. My friend and I were able to fix it with some JB cold weld and it's held for many months now.
Have you checked your charcoal canister and fuel lines? I'd think with the key on and the engine off (primed fuel system) any leaks would tend to show themselves.
Ever done a compression test?
-Chris
LaureltheQueen
- Spelling Nazi
Re: 8mpg, running rich, here are my scantool results
So? Did you guys fix the excessive fuel consumption?
Subaru Legacy BC2, EJ22, AT, 4WD '92
... This thread is 8 years old ...
She bought a corvette and sold her Legacy.stan31337 wrote:So? Did you guys fix the excessive fuel consumption?
