Using this ...
http://www.wallaceracing.com/0-60_equation.php
My 8.2 @ 88 - 3.81 0-60!
Zero to 60 times
douglas vincent
urabusturbo
EJ20G (GF8 TD04 version) in a 4EAT LSS with FMIC, 3"TBE, Tranny cooler, C-cupped, K&N in a ported airbox (4" inlet from fender well), Aeromotive FPR, Walbro FP - boost @ 9.5-10PSI (FCD=Dead) 0-60 = 6.47 seconds on a G-tech pro.
EJ22T on same car with all mods except Aeromotive FPR, boost @ 10psi, 0-60 = 7.48 seconds on G-tech pro in cooler weather, same stretch of road.
100% Stock @ 8.7 psi with no CEL's & a fresh tune-up the car did 0-60 in 9.70 seconds.
Its still slow but is getting better, I'm waiting on a new FCD so I can turn boost up to 15psi which should be much better!
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
0-60 = 6.07 seconds on a G-tech pro.
Boost on a TD04 90* inlet turbo = 13psi up to 4-4500RPM tapering down to 10.5 psi @ 6000RPM.
No brake torque or manuel shift mode, just put in in D & stomp the gas!
Still slow, but it is getting there.
Last test before 16G goes in = 15psi spike tapering down to the redline, I'm thinking that should get it into the high 5 second 0-60 range.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
SuperRallyRoo
well i just ran out and had fun today
I think its doing 0-60in about 5 seconds and seems to get to 100 in about 13 seconds that was with a skinny friend in the car watching the needle on a flat edit* (racetrack) on ramp.
thats with 12lb flywheel wrx clutch 4.11 turbo tranny full 3" exhaust vf8 turbo pushing 15psi theres more mods but not worth posting... not running lean till past 110mph
Legacyless
98 Jetta TDI
98 Jetta TDI
Finally got the HKS EVC in, boost now tapers down from 15psi (4000 rpm) to 13psi (6000rpm) 0-60 is 5.62 seconds & the 1/8th mile is gone in 9.21x seconds.
Again 4eat car no brake-torque, just put it in D & stomp the gas...
Perrin crank pulley going on this week, lets see what that does for 0-60 times (I'm thinking .1-.15 seconds quicker).
After that the TD04 will get ported, alky inj will go on, the fujitsubo e/l headers will be tested then the freshly ported 16g in my garage will go on the car.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
Just tested the car with alky inj. @ the same 15psi taper down as before.
The 0-60 time is now 5.05 seconds on the G-Tech Pro & 1/8th mile is 8.8xx
I'm injecting winshield washer fluid on a coolingmist basic 150psi kit available from Innovative Tuning.
For those who wonder how how accurate the G-Tech is I tested this on a friends car @ ATCO Raceway in NJ & the most innaccurate pass was as follows
ATCO 15.831
G-TECH 15.889
not bad in my opinion.
ATCO 15.831
G-TECH 15.889
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
