PM me your addressBAC5.2 wrote:oh shit, there are two single cam heads!
Is that an EA block on the bottom? I've never seen one torn apart.
I'm close enough! What's my prize?
Moved in with RS25
douglas vincent
here's a few of the mistakes you made on the guessing of the parts
4 Legacy Turbo wheels (sans tires) they are actually Outback wheels (polished lip)
Turbo Crossmenber 91 Turbo legacy
EJ25 (phase 1) block (no internals) actually its a phase 2
EJ22T block half (looks like it's the drivers side) with an EJ25 crank in it its actually again a phase 2 ej25
Pedal box (from an RS?)
A water pump (probably a turbo pump) is behind the crossmember
A metal oil seperator plate
Ashtray
There is an EJ25 with pistons in it its actually the other half of the block with the crank laying in it
A rear main seal
Elmers glue
Sandals
Jack handle engine stand handle
Ratchet strap
A box of engine accessories (coolant crossover, fuel rails)
Turbo heat shield
A single-cam head in the background you were correct, but there's two of them.. and they are turbo ones too
A FRAM 4460 oil filter
A pot in the way back
A trunk mat under the cardboard box
Some misc. sockets amidst some stainless steel mesh line they are ej25 piston pins not sockets
That's about what I can make of all of it.
under the white blanket is the oil pan and separator plate from a ej22t
but good job guessing the parts.. man you suby guys are a weird group of ppl.. thats why i like you guys.. lol
Ashtray
A rear main seal
Elmers glue
Sandals
Ratchet strap
Turbo heat shield
Dang, I was hoping it was a potential 2.4L setup with the phase 1 block (hence the EJ22t block half guess with the crank laying in it).
