Page 2 of 2
Posted: Mon Oct 29, 2007 6:22 pm
by IronMonkeyL255
shemoves wrote:The transmission I am using is from an '05 WRX, which requires male ended front axles. The '02 and '03 WRXs use female axles like the Legacy.
So, some unexpected snags, but if I can find the parts I need and the rest goes pretty smoothly, it will hopefully work.
Edit: If anyone has male ended front axles, please let me know as I need them.
I have some male axles from a WRX sedan, but they are too long.
Check out my thread about swapping in an '06 WRX tranny. I have the part numbers listed for the axle stubs so you can use the stock Legacy axles with that style tranny. I just did it in mine, so I know it works.
Posted: Mon Oct 29, 2007 8:53 pm
by shemoves
ah, good to know. I'll look for the thread. That would have sucked if I had bought '05 WRX axles only to have them not fit. So I know, I've got some early WRX female-ended axles, would those work with the adapters?
Posted: Mon Oct 29, 2007 9:55 pm
by n2x4
I did a drivetrain swap from an 05 WRX wagon into my 91SS. Slave cyl. bolted up for me.
Posted: Tue Oct 30, 2007 12:21 am
by shemoves
wierd. wonder why mine didn't.
