Do the new 2.2's use the same parts as the older 2.2's?
GLCraigGT
Post by GLCraigGT »
okay maybe a can answer a few of the questions.
A couple of weeks ago I change the Timing belt (13028AA102), Camshaft seals (806732150), Camshaft O-rings (806946030), water pump (21111AA007) and thermostat (21200AA072 & 21236AA010) on my 94gt. When I purchased the parts from the dealer I forgot to tell them that I have a single port EJ22 out of a later Subaru in my GT. All of the part worked just fine. I've driven the GT a few hundred miles since I did all of this work.
I do have a slightly off topic question. I am curious about witch version of the EJ22 I have. Dose anyone know if the Engine code is stamped anywhere on the block or heads?
There are three kinds of people in the world, those who can count and those who can't.
2009 STI, It's staying stock, well at least the first 100K
84 GL Wagon With Factory Brushgaurd, The Lack of Power Wagon RallyX machine.
wiscon_mark
Post by wiscon_mark »
Well, the engine code is stamped, but all it says is EJ22.
If it's single port, we know it's at least post-95, and it's most likely interference.
If it's the same timing belt then it's not the phase II engine.
So I'm guessing you have the interference version of the Phase I EJ22, which was (commonly) produced between 97-98.
185,000 miles
