I did not use the sixth wire so just tape it off if you want.yazmo wrote:hi guy i got my jdm fog light and the switch i got 6 wire like eveyone said.
The info is correct because my foglights are workingi just wanna know if this correct and where i can get
and what kind of relay i need.
As for a relay, just get any 5 pin bosch style relay
All of the 12v, ground, and accessory for the switch, came from the defrost switch wiring, IIRC the wire colors are even the same on both. So just match them up.i would like to know also where do i hook up the wire
when you said ground you mean anywhere to the chassis?
where do i get the 12v power same source of the radio?
and illumination accessory where do i found that ?
White gets switched 12v power from the relay, and the black goes to chassis ground.also those two wire on those fogs "black/white black stripe"
where do they go.
