Just another EJ22T (now stroker) w/2.5 DOHC Heads Build
Use the forum's search feature for info on the intercooler install. There are plenty of topics posted with pictures included of the install.
As for the heads, it's a mechanical swap of parts.
Jason
UPDATE…
Well after abusing the EJ20G swap for over a year a head gasket has started to let go. So the EJ22T stroker build is back on…
I have finished machining the case for the phase II STi crank, the last step for the case is bore and hone. I gasket matched the manifold and intake ports and smoothed all the ports and bowls. No real volume increase, just worked out the quirks and casting imperfections. Also machined the right head for coolant supply and oil return. Forged H-beam Scat rods have been added to the build and ARP studs as well. And I’ve started to layout my under manifold intake.
Now on to the eye candy…
Gary
Gary
Nice eye candy!
