06 intercooler question (with pic) i need a flange
Arctic Assassian
Haha no worries.
Just buy the one that was in that link or buy one like that off of ebay. I think I saw them for about $12 on ebay.
The 90* bend thing that was posted will work but it's a bitch and a half to get the nut to screw onto it.
The actual adapter piece is meant for the intercooler and will hold boost pressure without a doubt.
This is what you need.
http://cgi.ebay.com/ebaymotors/WRX-Type ... enameZWDVW
It's cheap and will work. All you would need is a 3/4" ID (IIRC) hose to connect that to the BPV.
*which nut to screw onto it?
ha ha you just posted!
you read my mind!
ok just bought that thinig you just showed me.
what is this 3/4 ID (IIRC) hose you speak of?
and will it connect to my crazy lowes object?
you kick ass asc,
zach
you read my mind!
you kick ass asc,
zach
Ok go back to Lowes and return the "crazy lowes object" lol.
You don't need that since you just bought this flange.
SO...
That flange a small tube sticking out of it. That tube has an outer diameter of 3/4" (measure it when you get it, just to be sure). Therefore, you'll need to buy a 3/4" inner diameter hose to slide over that small tube. Then the other end of that will connect to you bypass valve.
SO...
Ok so I edited this picture for you...
So get rid of the creepy thing and just add more hose to connect it to the adapter flange you just bought.
BTW, sorry for my crappy paint skills. hahaha.
ha ha ha! DAMIT!
i'm enticed too easily
ok cool, i think i can handle that, just buy a crazy tube with an inner diam of 3/4".
does it have to be a certain kind of tube? like should i go to the stealership and get one?
Or can i just exchange the crazy lowes object for a tube that will fit?
Will i need any other plumbing to make a 90* angle to the 3/4" tube so it'll run wherever it needs to be??
Just use some heater hose. You can get it at Lowes, too. In the plumbing section haha.
You shouldn't need any special tubing. Just straight 3/4" ID heater hose. Someone else can chime in and tell you if they've found something that works better.
Check on eBay - much cheaper. Doesn't have to be TurboXS lots of generic versions of the same thing.
Good luck.
Good luck.
You really dont need to shit on someone elses creative attempts at making something work. I dont know who made that lowes plastic elbow and thats not even really the point. The point is that its clearly working for the guy and he offered up a suggestion to a question that was asked. If I had done something different it would only have been to weld something up but i have access to a welder and can weld. Not everyone does. Its great that you offered the info on the ebay part but you dont really to point out the fact that the plastic elbow is "creepy". Maybe I'm just being sensitive but being creative and intuitive when upgrading these cars is what makes all of us unique. We cant, in most cases, just go to the store and buy a part to make something fit. We can however come here and see what others have done and get some ideas. That being said am I the only one who thinks that it pretty cool to have an ej22t in a 85 GLasc_up wrote:Ok so I edited this picture for you...
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
uh....?
we were not offending the Bandit that came up with this idea, i still have the lowes artifact of the gods and may still end up using it.
asc was kindly describing to me what i should do to get my new IC to work... and obviously {again?} we have vastly different vocabularies. and yeah we were joking around a bit, crazy turned into creepy and whatever.
we're a different generation
we appreciate the knowledge, otherwise we wouldn't be here contributing, and i think that picture also shows another way to install the 06 TMIC if im not mistaken.
GL's kick ass, and it shows at WCSS.
and +8 turned 90* for finding the perfect solution at lowes threeEyedBandit.
I never ranked on threeeydbandit for using that piece. Creepy wasn't meant to sound hurtful or offensive at all. It's just a weird object that surprisingly does work, hence the word 'creepy.'
I even USED IT MYSELF for a few months. Now I'm using that flange off of ebay and I personally found it easier to install the ebay piece because it's damn near impossible to install the nut on the back of the Lowes object. I'd be willing to bet that Threeeyedbandit will attest to that, too.
I was simply telling Zach how to install the intercooler BPV in (what I found to be) the easiest way possible.
I honestly wasn't trying to offend anyone, and I'm truly sorry if I did.
And I'm trying to show, that in this case, you can.magicmike wrote: We cant, in most cases, just go to the store and buy a part to make something fit.
I'm not in any way the sensitivty police on here. I just thought I would comment on how it read to me.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
ThreeEyedBandit
I took a quite a bit of pride on having you guys come up with such a kick ass unique name as the "Creepy Lowes Piece", maybe thats why I like this place so much
. I actually started taking pictures on how I installed mine to do a write up on how to install it the easy way.
Yes the first time I installed one it was a bitch, but I found a way to install it in under 2 minutes with the intercooler out of the car. Granted you need about 8 inches of 1/8" wire and a pair of pliers. I will finish it up this weekend and post it up. And I to find it freaking sweet to have a EJ-22T in a 85 GL Wagon.
Matt
Matt
Haha well just so you know, I wasn't trying to offend you or your creativity in any way.
I had tried screwing that nut on and eventually I went out to my garage and just epoxied the CLP (Creepy Lowes Object) on. Hahahaha.
So... How did ya hook up the y-pipe to the intercooler to the vf-11 with the stock inlet?
Yea but ThreeEyedBandit used a stock vf-11 with the 06 TMIC... He said he would take a pic of the moded ypipe...
