red=power, black=ground. I'm almost positive.
for power you can tie into the cigar lighter, or the radio. some people have even tied into the headlights themselves.
Fog Light Wiring Questions
someone have also post this in this post
Connect
Pin #5 to ground... ( defrost works fine)
Pin #1 to the acessory ( so the lights turn off with the car)
Pin #3 to the 85 port on your relay
Now... On Pins #2 and #4... These are illumination wires...
what i would like to know is which one is pin 5 pin4 etc.. and so on what color they are bcuz on my switch i dont see any number is the two wire up hat switch is pin1 and 2?
is those wire mark as 0.5 are power wire?
Connect
