I've learned to disconnect the speedo cable at the tranny, then feen some slack through the firewall. Then I can connect the speedo to the cluster, before I screw it it. As the cluster gets pushed into the dash, the speedo cable slack is taken out. Much more simple than trying to get at it through the bottom -- no way my big hands would fit through all those wires/crap.90leggy wrote:have fun putting the cluster back in, hooking up the speedo is a bitch, i had to lay with my head by the gas pedal, shove a hand up through there and have my other hand on the cluster. i might as well have been blind for it. ahahahah
How do I remove the cluster?
'11 WRX Limited
'94 TW | R.I.P.
