weird steering pop.......now with added problems
Bad ignition switch? Steering lock?
Post by SubaruNation »
like i go to turn the key and the key wont move forward.
key will not budge, even with my pythons (arms) working their hardest.... :(
the lights work though, so the battery is connected and electricity if flowing....just dont get why the key wont move and the car wont start.
oh, whats steering lock evolution?
my wheels are turned all the way to the left if thats what that means.
moved them with brute force to jimmy with that tie bar
internetautomart
Post by internetautomart »
SubaruNation wrote:like i go to turn the key and the key wont move forward.
<snip>
old key with worn teeth will do that.
that reminds me I need to throw out that key.
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
Steering lock locks the wheel in position if you turn the wheel. If that's the problem, turning the wheel a little will release it and allow you to turn the key.
the wheel as in the steering wheel right?
because i tried moving the wheels without using the steering wheel and they wont move back into position, whatsoever. :(
yeah that worked wonders. i thought it was the "wheels" that i had to move back into position, not the steering "wheel"
ugh... to the mechanic tomorrow then :(
Arctic Assassian
Post by Arctic Assassian »
wow.
Kickin' it old-school.
Arctic Assassian wrote:wow.
thanks for the input captain perfection! :smt023
if only we were all as helpful and thought oriented as you are...
like this response for example....
Arctic Assassian wrote:power steering rack take a crap? Check your powersteering resivior and tell me how much fuild is in it.
last time i checked cars don't have orifices or intestines for that matter :P
Arctic Assassian
LOL. Well, I guess I got a little spoiled working in a shop environment, and all my friends are at least as litterate as I am when it comes to cars. I'm surprised you've never encountered the steering lock before.
ok so update.
took it to da shop and they said $605 to replace the whole rack.
mother....
both inner tie rods also.
coould this be beause of the ps fluid in the power steering pump? son of a walrus, i doubdt i could do it myself but i wish i could so i didn't have to fork out six franklins on the dirty.
so much for an intercooler! :shock:
SO Gey.... whatever
the new name of my car from now on is money pit.
and arctic assasin,
i know more about cars than anyone in my house. my parents dont know anything what so ever, only my uncle does so i have some exposure but i learn the most on here b/c i cant be in my uncles shop as much as i would like to :cry:
you're lucky. i wish cars came to me as easy as computers/software and technology do. :x
internetautomart
most racks come with inner tie rods
Do the rack yourself for less than 1/2. There are two brackets to remove that hold it to the front underside of the crossmember. I'd recommend getting some Whiteline bushings to replace for the rack while you're there. You will probably have to spray the hell out of the bolts with at least some PB Blaster to make sure you don't snap a bolt - they're not very big so they can't take a lot of torque. You will have to approximate the alignment yourself when you adjust the tie rods, but it's not rocket science - just get the wheels approximately centered by measuring (or using string) on the front and backs of the tires to make sure they're the same distance apart. Then you'll have to drive somewhere for an alignment, but you're talking about saving hundreds of dollars.
[s0b story]
the guy hasn't done it yet but i think i'm just going to let him do it and bite the bullet this time.
when i changed a power steering line myself it to awhile b/c i wasn't used to working on the car.
i think i should stick to the basic stuff for right now, not quite sure if thats what I think but due to unforseen parental mind control powers and threats involving my car not being allowed in the garage again to work on myself.... i'm going to let them do it.
hopefully i'll have enough cash left to finish my new hood scoop.
[/sob story]
There's only one way to learn. There are some things you shouldn't try to do yourself (like synchronize the distributors on an old Ferrari V12), but worst case on this is that you have to tow it to a mechanic. See if he'll let you check it out on the lift so you can get an idea of what's going on with how it all works. It's all pretty simple when you see what connects to what and how they interact. I was told a dozen times how an engine worked when I was young, but it made no sense to me until I actually saw one as a moving cutaway. Then I felt like an idiot for not getting it sooner.
yeah, im more worried that the mechanic said that it was going to be a tough job.
this could be a ploy but we've been bringing our cars to this guy forever so i kinda believe him what he says.
i'm a victim of mind control :shock:
i hate decisions like this. saving 300 would be nice but theres all the control factors i have to put up with.
eff :x
thanks for the help though evolution, you kick ass! :D
It's not that hard. You loosen the bolt holding the rack onto steering column. Some have pins....mine didn't, or fell out. Next loosen the PS lines from the rack....they will pee all over the place. Remove the bolts holding the tie rods onto the spindle. Use a pickle fork to remove the tie rods, put a jack under the rack, loosen the bolts holding the clamps to the sub-frame, and lower the rack. That's all there is to it.
Yes the above is simplified, but it's not that difficult.
I like to use plastic hose clamps (look like plastic pliers with blades for the jaws) to keep fluid from pissing all over. They're cheap and don't damage lines (especially old ones) like small vice grips.
just a recommendation to anybody who reads this wondering about why their steering wheel wont turn a certain direction, find out what it is and fix it yourself.
ugh... works like a champ now anyway though.
i ended up needing an entirely new power steering rack and pinion... and tie bars.
and power steering fluid :lol:
so yeah..
Arctic Assassian
So did someone else do it... or did you man up and git er dun?
to spare you all the details (most of them are on this thread)
i didn't have time or the resources to do it myself, and my parents had some very pushy opinions about me doing it myself. gey, really gey.
i needed to drive my car as part of my job (hopefully for not much longer :x) so when i found out all that was wrong and what needed to be done exactly, i couldn't have all the parts i needed in my hands until way too late. so yeah, i paid the mechanic.
last time i'm doing that unless its something really huge.
Arctic Assassian
Glad its fixed at least.
yes sir, me too :-D
