VF11 + 06/07 wrx tmic intercooler install and other stuff
Post by SubaruNation »
Arctic Assassian wrote:Remember when I told you you have to get your hands dirty and figure it out, Had you not done that, everyone would've flamed you for that silly little metal hose, but instead, you searched, found the info, went to napa (alot, Just like the rest of us) and got the shit you need. You're going to be amazed at the difference those hoses will make. good job.
thanks :-D
you can't diss on the slinky though, well...yeah go ahead it's what ruined my car right now anyway :roll:
i had multiple rubber hoses before but they wouldn't stay on... and i knew the slinky wouldn't hold pressure but i tried it anyway b/c i've been working on this thing for like a month now.
Excitement got the best of me!
anybody got a stock 92-94 coolant tank? let me know PLEASE if so :D
i thought it was just the nipple but upon further examination, well.... yeah the tank exploded.
thanks!
biggreen96
Post by biggreen96 »
Hahaha zach I also have been to napa about 300 times in one week, they have sooo much of my money.
Invest in a few t-bolts, they will solve hose pop off issues.
I bought mine at a farm equipment supplier here in Moscow, Napa dude had no idea what they were :(
Damn those tanks are shitty, I have to thank DLC for installing a nice aluminum one from JC sports(no longer in business)
asc_up
Post by asc_up »
I couldn't agree more. He searched around and tried to find info and did what he thought was best. He tried, hit a hiccup and now he's on the road to success hahaha.
+1 for setting an example of how to use this board.
douglas vincent
Post by douglas vincent »
Search Ebay for the T-bolts. The chinese T-bolts kick the ass out of American. Cheaper and better. I am not sure why, but every chinese T-bolt I use is still working, while the American T-bolts gall up and are chucked after two uses.
Thanks Guys! :smt040
douglas vincent wrote:Search Ebay for the T-bolts. The chinese T-bolts kick the ass out of American. Cheaper and better. I am not sure why, but every chinese T-bolt I use is still working, while the American T-bolts gall up and are chucked after two uses.
ha ha that's kinda counter-intuitive :D
im searching right.............................................now.
i'm also glad coolant is cheap as hell :)
boro
Post by boro »
for the tank, just get some brass nipple and JB Weld (sounds kinky)
Did the same thing with my Saab tmic and the brass nipple haven't failed after a year or so.
91 SS Pearl White
>Apexi Power Intake, HKS 3" Downpipe, Saab TMIC, Blitz SS bpv, STi Shifter and Bushing, WRX Suspention and Clutch, Whiteline RCA Kit, Whiteline Steering Rack Bushings (sport), Ghetto HoodScoop
i considered doing that too, until i noticed that the entire top of the coolant tank (not overflow) was cracked and well really cracked, so i need a whole new one.
i could do that but it's plastic right?
i would have that done right now if ^^^ wasn't the case
smh0101
Post by smh0101 »
cough*** WRX coolant tank ***cough
Anyways.... The coolant tank aint nothin compared to a tranny...
smh0101 wrote:cough*** WRX coolant tank ***cough
that is true!
i don't wan to relocate the tank though, i mean i went through and thought of that einstein idea about how not to and well yeah.
how much do you think a rex on would be sir?
is that one metal?
:smt023 well presented also ha ha
and holy mother of five small otters, when did i surpass your post count?
i must be some kind of machine or something?.. :shock:
smh0101
Post by smh0101 »
single phrase "lol" post will add up!! lol jk
smh0101
Post by smh0101 »
And check NASIOC for them... I'm not sure how much they are.
and im back on. :roll:
the prices on the stock ones i've found range from 30 to 50 for the legacy ones.
uh, the wrx ones i still have no idea
this won't come off....
why?
im going to end up cutting it but i was wondering why it stays on there SO well, like i was standing on parts of my engine (stable) and yanking with all my might.
le ble
I can't tell for sure from the picture which hose that is -- is it the big one that goes to the back of the stock coolant tank?
But anyway... That just happens with old hoses. Twist and pull harder, or go ahead and cut it if you can replace it. It can also help to push it with a wrench that kind of fits around the pipe that it's attached to.
yeah i got it, it was just weird because 1st the hose clamp evaporated somehow :? :shock: then the hose wouldn't come off, had to cut it with a kitchen knife :roll:.
im putting the whole tmic back together AGAIN right now,
i'll update l8r :D
Get some picks. They look like large dental picks, come in different lengths and angles. You poke them under the hose at the stuck end and move them between the rubber and metal parts to break the seal, then twist them loose as much as you can. Just pulling on them hard enough to break the kind of seal they develop at that point can easily ruin them or severely weaken them anyway. You can do the same with a small screwdriver, but not when stuff's buried like that hose. Just be careful that when you use anything to poke them that you don't poke through them. Spray lubricant also helps once you get something under the hose.
duhn dun daaaaaaaaaaa...
new tank installed eh?
thoughts? is this the right one?
and...
this is my le problem.
gotta figure out how to connect these two.
gt2.5turbo wrote:th hose number is NAPA HOSE 8338. once you see the hose you will know what side to use. I cut my stock y-pipe after the ridges sith enought left to fit enough hose to fit in an exhuast pipe reducer to use to connect the hose to the turbo. the ypipe to exhaust piping hose was just a random rad. hose NAPA had that was big enough to fit over the ypipe. The site is down other wise id post a pic of the hose.
Yeah putting the ac under the pitchstop worked great
i know how to put everything together, im just worried about cutting another* 30$ hose the wrong way.
if anyone can interpret the red, that would be sweet.
and i just cut up a 30$ hose for nothing.
smh0101
Post by smh0101 »
Oops
smh0101 wrote:Oops
thanks.
asc_up
Post by asc_up »
And this is where the problem with 45* outlet lies....
smh0101
Post by smh0101 »
VF-12 here we come!
Which $30 hose was it?
smh0101 wrote:VF-12 here we come!
:shock: every single one...
napa 8338 or 3883... whatever the red hose in my picture says
