BUY MY CAR!!!! delete!!! sold, gone to new home
shtbxr22
Post by shtbxr22 »
almost forgot....I bought a cone filter, and MAF adapter to eliminate the huge ugly plastic restrictor(airbox)
1998 VW GTi VR6 5MT (SOLD)
what huh
Post by what huh »
can you post a link to your video i can't find it
1998 Legacy GT-T ... sold
shtbxr22
Post by shtbxr22 »
the_watts10
Post by the_watts10 »
yeah man i think that every body wants to buy this beast but unfortunately i dont have the money but really nice car man!!!!
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
what huh
Post by what huh »
sounds awesome man, i hope you find your wagon.
oh and the engine goes in your shell next week hopefully (but you know how that goes) i have be working on the engine as much as i can outside of the car
Post by SubaruNation »
the_watts10 wrote:yeah man i think that every body wants to buy this beast but unfortunately i dont have the money but really nice car man!!!!
take out a loan :-D !
Dynamic Entry
Post by Dynamic Entry »
SubaruNation wrote:
shtbxr22 wrote:Bridgestone RE92, 215/45ZR17
i almost bought those, but they were expensive as hell :shock:
kumho ecsta asx instead :wink:
I am gonna get these wheels but I am looking at RE70s instead. http://www.tirerack.com/images/trans.gif
Problem is that these are OE on STis and so the take off market is full of 225s, so I probs have to go retail. In which case I might do Kuhmo
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
that link leads nowhere.
and im not quite sure what you just said :?
Dynamic Entry
Hunh.... i guess I Fail
Someone buy this great looking Winestone!
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
Brat4by4
Stratified
Post by Brat4by4 »
What exactly are all the mods on this car?
And didn't you paint it recently? Any rust repair?
shtbxr22
Post by shtbxr22 »
Brat4by4 wrote:What exactly are all the mods on this car?
Not painted. I was thinking about it, but never pulled the trigger.
Rust starting @ rear fenders, and under drivers mirror.
157,000 miles
Mods: Manual Boost Controller
"coffee cup"
Flowmaster-Super 40 Muffler
Exterior: 02-03 WRX scoop
New USDM Headlights
JDM F. turn signals
2006 WRX Wheels
ADM Rear trunk piece
EDM Taillights
German plate
ADM RS Turbo decals
Interior: Grant steering wheel :roll: (too small)
Uninstalled stuff: SAAB intercooler
Invidia V3 catless DP
Maintenance stuff completed: New timing belt
ALL front seals
Oil pump reseal
New HLA's RH intake side
New valve cover gaskets/grommets
Various popped coolant lines(age)
Trans/coolant/oil flushes
new front/rear diff lube
OE spark plugs
OE PCV valve
OE Knock sensor
Air filter (swapped to cone)
Two new front axles
New front/rear pads, and rotors
New front ball joints
New front tierod ends
Aligned to factory specs
the oil has been changed every 1,500 miles since I've owned it,and I fill and drain 3-4 times when I change it. I wait until the oil coming out of the drain is totally clear. I have a free oil source. :wink:
Other things I have done are, New spoiler, new rear view mirror, new dash bulbs, new radio(OE).
The bad- Sunroof is sealed shut
Power antenna does not raise/lower by power.
:x Tranny has no 3rd/4th gear :x
(I have trans for it, w/ no front diff. needs
to be disassembled, and mated with mine)
shtbxr22
Post by shtbxr22 »
ok, so the brakes are on, the ball joints are in, the tierod ends are in, and the alignment is complete. the rear toe on both were way out, and the front camber, and toe on both were way out. now everything is kosher, and now the wheel is straight going down the road, and no more brake pulsation. :-D The intake is on now too. great sounds. check out the tierod picture. see something cool about these Japanese parts?
oh, yeah it's 555 :wink:
shtbxr22
Post by shtbxr22 »
yes, I still want a wagon :P
yeah and i'll keep helping you search :D
too bad you're really far away, otherwise i'd consider it :o
internetautomart
Post by internetautomart »
3k into mine would be repairing all my rust the right way, new trunk lid, sways, wheelsand tires, and a motor swap to an STi motor maybe.
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
shtbxr22
Post by shtbxr22 »
less than 3k for an STi swap....... :shock: you're insane!!
internetautomart
shtbxr22 wrote:less than 3k for an STi swap....... :shock: you're insane!!
it's all about connections ;)
though I'm already at $800 into my car on just maintenance and the price of the car itself :(
for the average joe, yeah 3k would be low for it.
i could give you 3k right now! :shock:
shtbxr22
Post by shtbxr22 »
update: the JDM turn signals are in. ( buy it, you know you want to)
I will be posting pics, probably this weekend inside, and out. I found the wagon I want NOW! :wink:
shtbxr22
Post by shtbxr22 »
bump! no pics today, sorry. the ride is dirty. :(
Legacy Rally Guy
Post by Legacy Rally Guy »
Yeah, the loan value on these cars is around 2700.. ^^ Or atleast they were when I bought mine with 160,000.. My bank dude was like "Wow, is it really worth that much?" I told him, well, actually to the right people it's worth nearly double in that shape. *mine's body is very straight and the undercarriage is perfect, needed an engine rebuild though, it spun a rod bearing shortly after seafoaming.. :P Yeah, when you "clean the oil system.." and it's super grungy, theres a possability you'll clog something else, while the crap is flowing through the oil passages... Seafoam does it job for sure.. almost a little too well......
oops sorry for the h/j, but yeah, if your banker doesn't mind the car not being 10 years old or less, a loan may not be a bad answer.
and you could always tell them you're buying tile flooring for your kitchen :-D
Banks loan a lesser percentage of the total every year the car is old. I doubt you'd get anything for it, but you could try a personal loan or something, though the rate might not be good. Then again, with the pathetic Fed we have hopelessly dropping the rate out of desperation and a lack of ideas, it may not be bad.
yeah that's what i was hinting at, the car is worth so little that it truly wouldn't matter what kind of small load it was, you wouldn't have to even disclose that you are purchaseing a car.
most banks will loan as much as 25K on a personal loan/whatever you want to call it... based on credit of course
Legacy Rally Guy
SubaruNation wrote:yeah that's what i was hinting at, the car is worth so little that it truly wouldn't matter what kind of small load it was, you wouldn't have to even disclose that you are purchaseing a car.
I've pretty darned good credit FINALLY, but my banks still very stingy. :P I can walk in and pick up a $3,500 school loan with deferred payments, but if it comes to cars or home repairs, they're like, "Welllll, here's the thing, we'd like to lend you the funds, buuut... Do you really need this (insert fun thing here)?
And I haven't had a late payment in years. Heck, it took four months to get the loan to buy my engine rebuild kit... It was all forged and badness, but still...
Yeah, I think the loan value on these cars is probably null now, the car being as old as it is; is likely to be a cash only purchase.. That is unless you buy it with a personal funds loan with the car as collateral. Banks dislike giving loans for autos with 100k miles or 10 years old AND hate giving loans on cars over 15.
I had 7k saved and my bank still wouldn't let me buy a 1968 Shelby 350 for $25,000... I was like you bastards, it's a good price and they were like, "hey, the cars wayyy too old and we couldn't sell it at auction for half that..." apparently they're not car people.
