Page 2 of 2
Posted: Thu Jun 05, 2008 12:46 am
by 555BCTurbo
92ss satinsvoice wrote:ya, plus with 155k one the original motor dosen't help ether.
My motor has 218k on it, and it works fine...
I know of an EJ20G closed deck shortblock for sale for $100 if you need something to get you back on the road...
Posted: Thu Jun 05, 2008 1:09 am
by 92ss satinsvoice
thanks nick i appreciate it. but i think im just goin to wait. my brothers letting me drive his honda.
100 bucks is a nice deal.
Posted: Thu Jun 05, 2008 1:12 pm
by BXSS
Wow - a EJ20G shortblock for $100 sounds good!
You can put the ej22t heads on the 20g & use the car while you build the new motor....
Posted: Thu Jun 05, 2008 4:47 pm
by smh0101
That seems like it would be quite the dog... seeing as the 20g has way less torque and the 22t heads have no top end...
Hmm... that would be interesting.
Posted: Thu Jun 05, 2008 4:55 pm
by BXSS
You may be surprised as the EJ20G shortblock is meant to be used with the big cc DOHC heads.
Once the small cc sohc heads are on there the compression will be higher than the 8.5:1 EJ20Gs usually have - ? 9ish:1 CR.
It should be a surprising little motor.
You get to drive your own car & build the 2.2 the way you really want to at your own pace.
Posted: Fri Jun 06, 2008 12:49 am
by 92ss satinsvoice
ya that would be and interesting setup.
give me about 2-3 weeks and she should be up and running again.
Posted: Fri Jun 06, 2008 4:03 am
by 555BCTurbo
smh0101 wrote:That seems like it would be quite the dog... seeing as the 20g has way less torque and the 22t heads have no top end...
Not really...I have ridden in a car with such a setup, and it was far from doggy.
Posted: Fri Jun 06, 2008 6:22 am
by asc_up
I think Tristan's car has that same setup actually...
Posted: Sat Jun 07, 2008 1:03 am
by 92ss satinsvoice
weird setup. i went to the mechine shop and for 20 thousants over bore and hot tanked. plus hot tanking the heads is about $142 total. cool..
