MPG Question
scuzzy
Post by scuzzy »
from a full tank of gas:
if I autocross on sunday: 20mpg
if I don't: 22-23mpg
car stats in my sig, I run relatively lean when I'm into the throttle (it's daaaangerous, but no knocking; I run 93 octane)
my commute is mostly interstate into work; 26 miles each way. usually stop and go but it's a mixup. some days are better than others.
#82 M4 TRSCCA Rallycross
RJ93SS
Post by RJ93SS »
so what should the average ej22t be getting when it's properly tuned up and running well?
asc_up
Post by asc_up »
I'm gonna say anywhere from 19-23 MPG based on your driving style.
yazmo
Post by yazmo »
i am doing like 280km for a 45 liter of fuel so i am like this guy who start this topic i got a very bad gas consomtion
im going nuts
ChesterKV
Post by ChesterKV »
yazmo wrote:i am doing like 280km for a 45 liter of fuel so i am like this guy who start this topic i got a very bad gas consomtion
im going nuts
Those numbers are foreign. What does that translate to in Freedom Units ?
EJ22 n/a installed in 1984 Volkswagen Transporter/Vanagon/Bulli
EJ22 motor with blown head-gasket undergoing rebuild to stock specifications
Subaru_Nation555
Post by Subaru_Nation555 »
For some reason when my fuel gauge hits the "E" mark, it has only used 10 of the 15.9 gallons. I guess it makes it easy to calculate MPG. I get about 155-165 miles out of 10 gallons of gas in the city so roughly 16mpg. Pretty lousy if you ask me. Cruising at 65 brings about 23mpg.
'06 Impreza 2.5i wagon
asc_up
Post by asc_up »
I'd get a new O2 sensor if I were you. 16 MPG is extremely low.
Subaru_Nation555 wrote:For some reason when my fuel gauge hits the "E" mark, it has only used 10 of the 15.9 gallons. I guess it makes it easy to calculate MPG. I get about 155-165 miles out of 10 gallons of gas in the city so roughly 16mpg. Pretty lousy if you ask me. Cruising at 65 brings about 23mpg.
When the light comes on it tells you there is 10L left in the tank. Not a good thing to run your tank dry supposedly :?
So I am realistically getting only like 250miles per 50L with a N/A legacy. I thought that was good but I guess it should be able to get closer to 300-400 range! I think it's time for a o2 sensor.
Aerotech
Post by Aerotech »
Check out this simple test... it gives you a rough estimate of what you car *should* be able to achieve measuring the coastdown friction over a measured time.
http://unwiredtools.com/utcoastdown.asp
Jerry
ciper
Post by ciper »
Couldn't you calculate exact MPG using the injector duty cycle and VSS1? The romraider logger does exactly this and its very accurate.
yazmo
Post by yazmo »
anyone have try this
Jet Chips Power Programmer
http://www.racepages.com/parts/performa ... ubaru.html
ZeroGF8
Post by ZeroGF8 »
My gas tank leaks when it is above the half way mark (found out the hard way :( ), so I only put in 20L when the needle is just below the E. I average approximately 175km per 20L with 90% city / 10% highway driving which isn't too bad on a stock 325,xxx km EJ22T.
93 BC6 white
internetautomart
Post by internetautomart »
ericem wrote: Not a good thing to run your tank dry supposedly :?
it's not good for a couple of reasons
1. the crap in gas settles to the bottom of the tank so that is what is left when you get down low (or something like that according to "conventional" wisdom)
2. if your fuel pump isn't immersed in gas it can run hot and burn out over time. that is why keeping over 1/4 tank of fuel is recommended for optimum fuel pump life.
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
I've opened up my gas tank to get at the pump more times then I care to admit. None of the times have I really seen any "crap" in the bottom of the tank.
Plus, the way the pump is situated, it's going to pull the crud up regardless of whether the tank is low or not, since the pump sock is sitting at the bottom of the tank.
The internal flow of the fuel is what cools the pump/motor. Designers would not design it to need to be cooled by external fuel around the pump.
internetautomart
Legacy777 wrote:I've opened up my gas tank to get at the pump more times then I care to admit. None of the times have I really seen any "crap" in the bottom of the tank.
1st part you may be correct on, but the pump is designed to be cooled by the fuel surrounding it. That is why there are different pumps for in tank and external use.
internetautomart wrote:1st part you may be correct on, but the pump is designed to be cooled by the fuel surrounding it. That is why there are different pumps for in tank and external use.
I'm not a fuel pump designer, so I can't say for sure, but I can't see the only difference between an internal & external pump is that the internal pump is designed to be cooled by the fuel surrounding it.
I agree with you that the pump will be cooled by the fuel surrounding it, but to say that you're going to get less longevity out of the pump because you don't keep a 1/4 tank of gas is a little far fetched. There are MANY vehicles with in-tank pumps with well over 100,000 or even more miles on the original fuel pump.
I would think the difference would be the outside tank would be weather resistance and possibly a different housing that would allow it to draw a vacuum through a hose upon start up.
