My throwout bearing has been squeaking since slightly after I changed the headgaskets. So I bought a new one and some kartboy parts:
I had an sti transmission mount sitting around:
The stock 5-speed one looks like this:
I figured the 6-speed part might be better. Plus it goes along with the sti motor mounts I'm using. To install all this stuff step one is to remove the transmission. I modded our jack so that I can bolt the transmission mount directly to it:
Here's the tranny:
It was pretty dirty so I cleaned it:
Then I took apart the crossmember and replaced the rubber bushings with urethane:
Then replaced the rear shifter stay with the urethane kartboy part:
Put on the new throwout bearing:
And re-installed the transmission, put in the front shifter bushings, and also the driveshaft and whatnot had to go back on:
Okay that's about it for now. The biggest thing I've noticed is the shifter feel due to the front and rear busings. Doing the outrigger bushings created a growl on decel, and all this stuff hasn't added too much nvh. the drivetrain is a little louder on acceleration now but that's about it.
