The problem with what you're stating is just pure opinion, No factual basis. No one type of Oil (say Mobil 1 vs Castrol Syntec) is the same as the next. They all have proprietary (sp) formulas. They are all going to perform differently in a given engine. Whether just driven everyday or at the racetrack.evolutionmovement wrote:I think the real life difference between synthetics is negligible outside of a racetrack and no marketing department lit will convince me otherwise. Maybe Royal Purple or whatever's the best, but with how my engine looked with Mobil 1 changed every 7500-10,000 miles I don't see an advantage. And I don't necessarily think the results would've been much different with any other synthetic. Were I ever rich and stupid enough to buy something gay like a Bugatti Veyron to drive in heavy summer traffic, I might care about the differences then, but this isn't the first thread on this topic and how far it's gone is ridiculous (I recognize my contributing to it). We're talking about a pretty unstressed 2.2 engine, here. I only bother with the synthetic for the longer change intervals.
You state how your engine looked. Looks are not everything. Show us some Used Oil Analysis' that show low wear numbers, that back up your chosen OCI. Some people like to say I change my oil when it starts getting dark. While the oil may be getting dirty, without a UOA, that person is just blindly guessing that the life of their oil is used up.
That's why I gave my wife's car as an example. I found a conventional oil that gave better wear numbers with a longer oil change interval than someone running Mobil 1 in the same engine (similiar climates and driving routine) for a shorter oil change.
I'm not up to speed on all the Subie engines, but I thought the little 2.2L N/A motor in my 92 used a Hydraulic style lash adjuster. Have to forgive me but I'm used to pushrod engines.PhyrraM wrote:Care to explain this? Many-many OHC and DOHC engines still use a sliding metal, non-hydraulic valve opening mechanism. Including Subaru. They don't call it flat-tappet anymore (we call it shim-over-bucket), but functionally it's still the same.Buffman wrote: Today any API SM rated OIL will be fine for use even in older cars as long as they don't have flat tappet cams.
Older API cert oils SL and before usually have higher levels of ZDDP in them. ZDDP is a very good additive for use in cars that employ a flat tappet style lifter/cam assembly
