Manual Seat Belts
ride_child
Re: Manual Seat Belts
Post by ride_child »
whelp this is in my wagon, should it be in the same location?
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
I know I'm late to the party, but can tell you what I've found.
So the seatbelt computer also controls the key chime. So I did not want to eliminate the seat belt computer. I bought a manual seat belt computer to swap in to retain the light and key chime, however there are some slight differences that would require some wiring changes. I never got around to the wiring changes, so in the mean time (going on several years) I just pulled the pin for the seat belt light out of the seat belt computer harness. If I ever get around to swapping the seat belt computers all I have to do is put the pin/wire back in the connector and things should work fine.
In just using the auto seat belt computer, the key chime works and the only issue I get every now and then is the seat belt computer relays go a little crazy and click a few times. Hopefully life will slow down at some point and I can work on the car again, but I don't have grand delusions that will happen any time soon.
