Page 2 of 2
Posted: Fri Nov 27, 2009 5:21 pm
by kimokalihi
That guy had covers on the front wheels which were on hinges I believe and had rollers on the inside so when he turned the wheels it would push the cover open to make room for the turn. At least that's what I understood from reading that. I thought that was a pretty cool idea. Would probably make a lot of noise though and I wonder if it would wear on the tires over time.
Posted: Fri Nov 27, 2009 8:06 pm
by gijonas
You think too much.
Posted: Mon Jan 04, 2010 8:02 pm
by turbo_meow
that is sick want a set up
Posted: Tue Jan 05, 2010 4:51 pm
by fatgc8
Hey guys,
I just wanted to chime in and everyone know that the new S/C TT setup is on a built longblock with a T/C 40r. I will have updates and videos as things progress. Right now we are in the process of working out a tune with the AEM standalone and some other little things to make this kit really shine. For right now all I can really say is the "Power under the curve" is going to be nuts. Sorry for the bad pics...
Posted: Tue Jan 05, 2010 10:54 pm
by Mattheww044
there needs to be a "jizzed in my pants" emoticon
Posted: Wed Jan 06, 2010 2:25 am
by kimokalihi
Agreed. Also a "Like a BAWSS!" icon.
Posted: Sat Jan 09, 2010 5:01 am
by MikeyMeyagi
Holy complicated batman!!
Posted: Sun Jan 10, 2010 8:30 am
by douglas vincent
Hey, I did it CHEAPER!
But mine looks like ASS!
Posted: Sun Jan 10, 2010 8:45 am
by magicmike
seriously, what is the point of a supercharged turbo setup? What? your your turbo boosts to 21 psi just in time to get restricted by the 1.5 psi supercharger? I dont get it? Wea re talking about two totally different boost curves at the same time.
Posted: Wed Jan 13, 2010 5:17 pm
by 93Leg-c
If I understand their setup correctly, the supercharger cuts out when the turbos take over. So, you get the best out of both systems. So, no turbo lag on the low end, and no supercharger parasitic drag on the high end.
Posted: Wed Jan 13, 2010 5:38 pm
by kimokalihi
Exactly. At a certain RPM or boost level, not sure which, it disengages the supercharger.
Posted: Wed Jan 13, 2010 5:41 pm
by Lunatech
Oft times I've wondered if that were possible. All the superchargers I've seen look like if it's not turning there could be no air flow through them.
How do you suppose this is accomplished?
Posted: Wed Jan 13, 2010 6:19 pm
by kimokalihi
Bypass it.
