Page 2 of 2
Posted: Tue Dec 29, 2009 11:39 pm
by evolutionmovement
I'll second the OEM PCV.
update
Posted: Wed Dec 30, 2009 12:50 am
by Florin1
Thanks to all who gave me all the tips!!! Bled my lifters today and slapped it all back together.. and?... SUCCESS!!!
No more rattle!! I'm so happy. thank you guys very much. Now i just gotta find a place who sells silicone hoses so i can replace my broken boost control line. Any ideas where i can go to get one? I'm north of Seattle, in Lynnwood. I took some cell phone pictures of the actual bleeding process for future people, because i couldn't really find any in the searches. Here the are:
rocker taken apart. (probably doesn't need to be done but i wanted to inspect and lube everything)
Pulling the lifter (i ended up using needle nose for all)
I completely submerged the lifter in motor oil and pushed it against the bottom for pressure, and than stuck a tack in the hole to push the ball. Than air would come out. I repeated the process until no more bubbles came out on each lifter.
Posted: Thu Dec 31, 2009 3:01 am
by subytech
I'd just like to add that talking to all the old timers and master techs at my dealership they all say thay there really isn't any reason you can't save an HLA all you need to do is soak the really stubborn ones in some solvant and exercise them while in the solvant. Can't say I've actually done it but have seen some really bad one fixed this way at work.
Posted: Thu Dec 31, 2009 3:36 am
by Florin1
subytech wrote:I'd just like to add that talking to all the old timers and master techs at my dealership they all say thay there really isn't any reason you can't save an HLA all you need to do is soak the really stubborn ones in some solvant and exercise them while in the solvant. Can't say I've actually done it but have seen some really bad one fixed this way at work.
Thanks for the info. I may have to do that since i think i may hear the sound starting to come back.
Re: 94 Legacy Sport RATTLE??
Posted: Thu Jul 22, 2010 7:59 pm
by yazmo
hi guy look good, nice post great and pic too
i want to do the job.
but my engine dont sound like your mine s really tic tic tic tic sound
Posted: Fri Jul 23, 2010 6:17 pm
by yazmo
also i read josh say by the mean time when doing a lifter job you should replace grommet?
i try to look what grommet is on haynes manual i dint see anything about it!
also try to find the gasket for the valve cover on google nothing come out.
i really to would like to get this done before im getting back at work?
so if anyone as part number for these pls let me know
