Page 2 of 2
Re: FS WA parting out 91 SS
Posted: Wed Apr 13, 2011 11:28 pm
by toomuch
Sorry no fenders.
I should have the sway bar, there are two styles if you can confirm which you have. One has a bolt through the lateral and one uses a link set up. I'm in Olympia.
Posted: Thu Apr 14, 2011 9:16 pm
by klaxed
Either or work for me. My current wagon doesn't have a sway bar set up in it. I would prefer the setup with the c-links over the drop-through links. Do you have the rear lateral links, mounting brackets and the necessary hardware to bolt it up with?
Posted: Thu Apr 14, 2011 11:00 pm
by rockon99
How much for the grille? It'll fit an L right? I want it..
Posted: Fri Apr 15, 2011 2:31 am
by toomuch
klaxed wrote:Either or work for me. My current wagon doesn't have a sway bar set up in it. I would prefer the setup with the c-links over the drop-through links. Do you have the rear lateral links, mounting brackets and the necessary hardware to bolt it up with?
I can check this weekend...
Posted: Fri Apr 15, 2011 2:35 am
by toomuch
rockon99 wrote:How much for the grille? It'll fit an L right? I want it..
Yes they should be interchangeble if you have 90/91 pre-facelift. I think this grille is from a LS it has the cross pattern not like the turbo style. I can send picture if you send me an email addy.
Posted: Fri Apr 15, 2011 8:47 pm
by rockon99
Oh i was thinking it was like the turbo/touring/Mi style grille. I'm looking for one of those. thanks though
Posted: Sun May 08, 2011 5:56 pm
by toomuch
Klaxed, tried to PM you a couple times, for some reason they are stuck in my outbox, not sure what I'm doing wrong. Anyway I have all of the sway bar bits, let me know if you want to get them.
thanks
