Turbo Inlet 90 Elbow No Longer Available
James614
Re: Turbo Inlet 90 Elbow No Longer Available
Post by James614 »
diesel devil wrote:I can get the original hose that fits I just ordered 2 more today $59ea. I will gladly help out and offer to buy out all the remaining stock so we can share
Wait, so Canada has had the standard EJ22T hoses in stock this whole time? You hoarders!
wtdash
Post by wtdash »
$59 CAD is less than original USA cost.
I forgot about the Canadians getting the same car.
EDIT 7/31/12: I just confirmed w/Richmond Subaru near Vancouver, BC they are in the Toronto warehouse @ $64.87 CAD + shipping, so 'diesel devil' is making y'all a good deal.
Same Part Number in Canada, too.
Get 'em while you can!
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Alphius
Post by Alphius »
I would like to get one from Canada! :) Good find guys.
oldscoobyturbo
Post by oldscoobyturbo »
Enjoy this taunting pic from today see the date?
if anyone wants to arrange a big order let me know I can get more.
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
ride_child
Post by ride_child »
does anyone know if you can still get the intake elbows for the 20g? or if an aftermarket elbow will work? ive converted from the 22t elbow and dont want to switch it back.
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
86BRATMAN
Post by 86BRATMAN »
lol, I posted the same part a weeks or so ago in another thread
I scout ebay for probably an hour every morning haha.
ride_child
yea im not tryin to pay 70 bucks for used oem part. especially when it isnt the same boot that i got with my 20g heads! but yes , i did see that part on ebay too haha
Kris
'91 Black SS - SOLD
BoneIslandScooby
Post by BoneIslandScooby »
vrg3 wrote:Hm. Here's an idea:
Install an MBC so you don't have to worry about the stock boost control valve plumbing. Then, put a check valve in the hose going to the middle fitting of the charcoal canister, so you can get rid of the auxiliary purge plumbing.
Not sure where this is. Which of these tubes are the auxiliary purge plumbing and where is charcoal canister? Which way does check valve go? I would imagine I follow the smallest vacuum hose from the intake resonator to some sort of vacuum fitting manifold that has three outlets. The middle of the three will be the one that was connected to the intake resonator. I would need to put a check valve in there, correct? Now, which way does the check valve go? Suggestions for source of check valve? As it stands if you've used a MBC and you've installed a check valve in the middle fitting of the charcoal canister, we have eliminated two of the hoses connected to the intake resonator. The only one left is the Idle Air Control Valve fitting.
vrg3 wrote:Now, get a piece of 3-1/8" pipe (the elbow coming off the MAF has an 80mm ID, close to 3-1/8"). Weld/solder/braze/epoxy/whatever on two 3/4" OD elbows (one for the IAC and one for the BOV), and a couple of 1/2" OD fittings for the PCV (probably one elbow and one straight). This will replace the resonator and everything that used to attach to the stock boot will attach to it.
I would imagine the fittings mentioned here are plain 3/4" OD and 1/2" OD tubes (90 degree bent or straight) which are welded on to the intake pipe (coffee cup mod) so that they can have IAC, BPV, and PCV hoses clamped to them, correct?
Boneisland, check the diagrams in the first link: http://bbs.legacycentral.org/viewtopic.php?f=1&t=15268
Should help.you visualize.what vrg3.is talkng about.
You can just cap off the auxilary purge or run a non-turbo charcoal canister. I'm running a non-turbo charcoal canister as it cleans things up a bit.
James614
Post by James614 »
http://www.rhdjapan.com/subaru-oem-maf- ... ied-c.html
Stumbled across this guy. About $41, I caculated shipping to about $37 with Fedex or $12 DHL to Portland, OR.
Mister Anderson
Post by Mister Anderson »
I'm going to give RHD-Japan a try. My intake is a V1 STi, so this will actually work out better for me. I'll post my experience with them here.
robertpaige
Post by robertpaige »
Let us know how that works, I have a TD05 with a 90 degree inlet and would rather use that elbow than the makeshift one I have.
I have the JDM elbow also, and it fits the td05 much better than the 22t one.
robertpaige
Mister Anderson
robertpaige wrote:Let us know how that works, I have a TD05 with a 90 degree inlet and would rather use that elbow than the makeshift one I have.
It might be a few weeks, they have ordered from Subaru. Eventually this hose will end up on my sedan. I just wanted to break the wagon's engine in with the stock set-up. My wagon will be running the inlet under the intake manifold.
Mister Anderson
Got the new elbow a week and a half ago. Nice and soft, and is a genuine Subaru part.
RoughDiamond
Post by RoughDiamond »
Has anyone considered using solid tubing (like copper or aluminum) so you can braze/weld in the needed bungs and use silicon couplers at the turbo and resonator box?
1991 Legacy SS (BC) EJ22T // 4EAT // Pewter Metallic (Sold)
1991 Legacy SS (BC) EJ22T // 5MT // Rio Red (Sold)
1991 Legacy SSRS (BC) EJ20G (Full COP and AWIC Swap) // 5MT // White Pearl Tri-Coat Africa Rally replica in progress.
James614
Post by James614 »
Its been done but some others. Certainly a workable solution if you're able to fab it up.
Soobster
Post by Soobster »
My elbow was toast, but I had to reconfigure the intake anyway since the engine is now in a Vanagon. But, it definitely can be done.
https://www.thesamba.com/vw/gallery/pix/1752734.jpg
https://www.thesamba.com/vw/gallery/pix/1763816.jpg
1987 VW Westfalia Vanagon - EJ22T Powered
1994 Legacy Touring Wagon
That looks good!
carfreak85
Post by carfreak85 »
My Samco hoses work great! Ordered for my JDM EJ20G and it took a few weeks to arrive (hand made to order), but they fit perfectly!
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon & Hardtop
1987 & '87.5 RX coupes
1987 RX Type-RA
2002 WRX sedan
2019 Outback 2.5i Limited
How many weeks did it take? Mine have been on order since March 12th.
