Re: Better intake manifold for my ej22t?
Posted: Tue Aug 07, 2012 5:31 pm
Injector duty cycle is a function of airflow. The turbo's ability to move air through the engine is a function of the modifications. A normal TD05-16G on a completely stock engine with stock exhaust and intake will be fine on wastegate boost.
I am running a ported & polished TD05-16G which will flow more air, and had a modified intake and 3" TBE and ran just below fuel cut on a stock engine without any problems. AFR's stayed around 10.5-11 to 1, which is normal for the stock ECU. You should be fine.
