subie ran for 10 and died w/ out restart
turbo970
Re: subie ran for 10 and died w/ out restart
Post by turbo970 »
well new sensor instatlled but still wont drive. i noticed on the harness to the tps that the black and red wires were loose and when i bumped them the car would stall. would a connector from a n/a tps work. because that is the only one i can get from junk yard here
Yes, the TPS and wiring is the same between the turbo & non-turbo Legacies.
turbo970
Post by turbo970 »
sweet i tried fixing it but all it would do is a real low idle with the throttle floored for like 5 mins then would idle up then when i put it in reverse it would idle down and shut off. i'm bout to sell this car or part it out. only to shops will work on older cars here but i gotta wait a week to even get my car in
turbo970
Post by turbo970 »
well the subaru tech found the timing to be way way off need to see if its a belt issue or somethimg more
