Timing is done, car won't start.
Re: Timing is done, car won't start.
Sounds more like a big vacuum leak. Double check all the hoses to see if they are on secure?
Last time I forgot a vacuum line, the car wouldn't even stay running. I've had the battery disconnected for over a day now and I'm gonna check all the grounds under the hood and see where that gets me. I'm still a bit baffled by the TPS code cause the TPS tests just fine, according to the Haynes manual.
Danny
Double post, oh well. I fixed all the issues today and it was something super simple, make me feel a bit stupid for not thinking to check what I did. If I hadn't met up wit hbeatersubi sunday, I don't think I would have found the issue. His suggestion to check all the grounds led me to check the two square connectors that go to the motor and those weren't totally together. I was able to simple unplug them by pulling alone, so I made damn sure they did click together and all the issues are gone. The oil light works again, the stumbling is gone, and there are no codes. I am so relieved that its fixed and working properly again. Now I can go back to getting regular unleaded and going anywhere I want.
Danny
Good deal. Always makes you feel stupid, but then relieved when you find the stupid mistakes.
Guarantee you won't make those mistakes again.
