MY94 Turbo Legacy From Montana
Re: MY94 Turbo Legacy From Montana
Nice pictures.
I like the black and gray headliner. Looks good.
DougFresh
Post by DougFresh »
Thank you!
I have put a Black suede headliner in my 04 STi and my Legacy. My 00 swapped Impreza I had a Blue Suede Headliner. its amazing how much the headliner can change the feel on the inside of the car.
Yeah that's very true! It's like painting the walls in your house....it just changes the entire look.
DougFresh
Post by DougFresh »
Touche! Couldnt agree more! maybe one of these days i will do a write up. its just such a PITA to get that headliner out!
Yeah...I can imagine....I wouldn't want to take mine out!
legsportwag
Post by legsportwag »
Were in mt? Looks like gf to me.... killer lookin ss btw. Helena here :)
DougFresh
Post by DougFresh »
Billings brotha, im on BSS :)
also on Mysicksubaru.com
UPDATE:
I have been doing a headgasket(s) repair as well as fixing all other leaky gaskets. I will have pictures loaded probably sunday. Hopefully have the engine back in the car tonight.. hopefully!
DougFresh
Post by DougFresh »
TD04
DougFresh
Post by DougFresh »
an issue i have not been able to figure out.. why the RPMS randomly will just climb at IDLE (up to 2500RPM). Also the battery and brake light come on randomly. i have read that it could be the alternator. The alternator tests fine, i am thinking i have a bad ground somewhere. yaaaayy.
but no more oil leak! *fist pump*
DougFresh
Post by DougFresh »
i think it could be an o2 sensor, MAF or TPS.
most likely 02 and MAF causing problems.
tsbpenguin
Post by tsbpenguin »
Car looks great, you have done really good work. The only advice I'd give is to find a better spot for your filter. Sitting over the engine bay like that it has got to be just soaking up and sucking in heat, working against your fmic. Plus you have no distance between the filter and the MAF which can cause the MAF to get bad readings due to turbulence and such, especially around idle. Try to find somewhere that you can shield it from the engine bay, preferably by one of the fenders so you can expand the opening into the fender well and get nice chilly air all the time.
In between Subies
DougFresh
Post by DougFresh »
hmm maybe thats why i am having such bad fuel mileage is due to my custom/ghetto intake.
I never thought of that!
I will try to fab up a new intake. thank you for your input and advice!
Post by SILINC3R »
Can't believe I just found this thread, lots of winning
DougFresh
Post by DougFresh »
Thank you!
everyone has made me feel at home here :)
DougFresh
Post by DougFresh »
installed new crank pulley due to old crank pulley being damaged. car runs great.
now if i can figure out my damn alternator issue then i think the car is golden for 100k :)
DougFresh
Post by DougFresh »
picked up a downpipe and up pipe (3") for $40 on friday. going to order a grimmspeed adapter to convert from 3" to 2.5". then install manual boost controller. then wham bam. then its to fix a few more maintenance items.
one day i will get some window tint.. haha.
DougFresh
Post by DougFresh »
next weekend i am installing my downpipe and my new area1320 electronic boost controller and running a mbc at the same time. :)
Alphius
Post by Alphius »
MBC for overboost protection?
DougFresh
Post by DougFresh »
correct, the electronic will help regulate different barometric pressures while the MBC will keep it locked in from going above a preset limit.
I heard it works pretty well, but can be a pain in the rear end to get it set up. i may ditch the EBC and run just MBC.
Alphius
Post by Alphius »
Yeah, that's a good way to run things. I was thinking of doing that in my SS before I sold it but ended up just using the MBC on its own.
DougFresh
Post by DougFresh »
hopefully have my downpipe on this weekend. ill post some pictures if i get time to do it tonight.
