Alternator from 06-07 B9 Tribeca - 3pin connector?
Re: Alternator from 06-07 B9 Tribeca - 3pin connector?
More than likely, you're looking at the wrong wire. That wire is the one that goes to the starter.
There is one on the manifold....that is the one I'm talking about.
free5ty1e
Post by free5ty1e »
Ah, then I still havent found this grounding point yet... I thought I had finally found it with the photos I could find of it but im confused again lol.
Ill post if I find it :)
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
-Chris
91SS 4EAT stock, 200k mi
If you take some pictures of a wire in question i can tell you whether that's it or not.
free5ty1e
Post by free5ty1e »
OK, thanks -- I will probably be able to get a good look in the '92 in the near future as it will be quite apart in my garage for a timing belt / seals and valve cover gaskets. Perhaps I'll be able to find this hidden ground then!
-Chris
