Good you noticed that.
I like the idea of testing the pressure right at the pump. I will try it.
Oil Pressure gauge reading 0psi at idle..
Re: Oil Pressure gauge reading 0psi at idle..
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
Yeah....that's a good idea about testing the pressure at the pump. Even the standard pump will generate sufficient pressure.
Maciek, I'll be curious to see what pressures you read directly from the pump. I don't understand why your pressures are so low unless something is wrong or there's an obstruction.
