Page 2 of 2
Re: Oil Pressure gauge reading 0psi at idle..
Posted: Sun May 11, 2014 7:52 pm
by macipusy
Good you noticed that.
I like the idea of testing the pressure right at the pump. I will try it.
Posted: Mon May 12, 2014 5:48 pm
Yeah....that's a good idea about testing the pressure at the pump. Even the standard pump will generate sufficient pressure.
Maciek, I'll be curious to see what pressures you read directly from the pump. I don't understand why your pressures are so low unless something is wrong or there's an obstruction.
