jessmans rio red 91 SS EJ20g swap lots of pics
Re: jessmans rio red 91 legacy ss EJ20g swap
jessman1942 wrote:YESSSSSSSSSSSSSSSSSSSSSS finnally got my jdm gc8 ej20g ordered should be here in a couple weeks
It looks like you can probably use that 20G power steering pump, or you can use yours if the lines don't match up. However, you may have to swap reservoirs, IF they're interchangeable.
jessman1942
Re: jessmans rio red 91 SS EJ20g swap lots of pics
Post by jessman1942 »
geez man that's not reassuring lol
88 Honda civic wagon B20VTEC SWAP-RIP
85 Subaru loyal sedan-SOLD
95 Subaru impreza $500 BEATER-SOLD
91 Subaru legacy SS jdm ej20g swap
CHECK OUT MY ej20G BUILD HERE>> viewtopic.php?f=25&t=53766
jessman1942
cj91legss wrote:It looks like you can probably use that 20G power steering pump, or you can use yours if the lines don't match up. However, you may have to swap reservoirs, IF they're interchangeable.
Alright that's what i was hoping to be able to do :smt023
jessman1942
SO i finally had some time to get more done on the legacy. I got the car moved to a new location, i now have a garage to work in for the first time ever
Definatley a first for me pulling a Subaru motor i was extremely paranoid i was gonna break something but as a matter of fact it turned out to be alot easier than any car iv worked on thus far so pretty happy about that
I was pleasantly surprised to find i had an ACT street lite weight flywheel and stage one clutch setup on the ej22 :smt023
The bay was extremely dirty with 20 years of grease and dirt, So we had to stop and get a pressure washer to clean everything up.
Got the trans out and started stripping down the block to a short block i have it sold for $400 and the turbo
Image[/url]
This motor is SOOOOOOOOOO dirty, I hate how bad these boxer motors can leak
Got the block all stripped down and in the back of my car ill be selling this tonight
Now that i have that squared away back to the bay it got a nice cleaning and degrease.
Nice little before and after :smt023
ride_child
Post by ride_child »
looking good dood! i had the same experience when pulling my first suby motor, wa easier than anticipated!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
jessman1942
ride_child wrote:looking good dood! i had the same experience when pulling my first suby motor, wa easier than anticipated!
Thanks man, Yeah this is a lot easier that i expected im dealing with issues on my 20g now im lost where to put the wasted spark coil pack or where to get longer Subaru spark plug wires :(
I started out with just leaving the coilpack on the top of the manifold. I used 1996-1997 legacy GT spark plug wires and they fit perfectly.
Not liking that setup, I made an L shape bracket off where the ac used to go, ran the coil pack north to south. For plug wires i bought a set of MSD custom wires for a V8 (my parts store didn't have the set for 4 cylinders), and cut them to length.
jessman1942
mike-tracy wrote:I started out with just leaving the coilpack on the top of the manifold. I used 1996-1997 legacy GT spark plug wires and they fit perfectly.
That was my first idea theirs two bolt holes on each side on the intake i could make a bracket to securely mount the coil is that what you kind of did and the ej25 wires are longer? mine are close but don't reach
jessman1942
Im kind of worried its gonna hit the hood.
Mine rubbed the insulation in the hood. I put a piece of cardboard for temporary. The 96-97 2.5 engine both was dohc and had the same coil as the ej22t so the length and figment was perfect.
jessman1942
I think I'm gonna get a set of those plug wires and see how they work you did that on a 20g swap like mine correct? Also are the wires 90 degree angle where they go on the plugs ? Thanks for the advice man
I had an ej20g swap just like yours. They worked perfectly. I just didn't like the coil pack hanging out on top of the manifold unsecured.
I made a bracket out of 1/16"aluminum that bolted to the top throttle body 12mm bolts and folded over on to the top of the manifold and bolted my coil pack to it.
Sent from my SGH-T889 using Tapatalk
jessman1942
Well id love to just have the coil pack mounted to the now empty ac bracket but this was what i was thinking to get my car running how important is the grounding of the coil pack what are your guys thoughts on this ?
The coil pack doesn't really ground through it's connection to the manifold, so that shouldn't be an issue.
Also, just a tip, the hood can be raised higher which helps with getting the motor in and out. This scan from the owner's manual shows how you can adjust the hood prop (top left).
http://www.main.experiencetherave.com/s ... ns/063.jpg
jessman1942
sorry for the halt of update pics iv started a new job more money for more car parts i promis i will organize some more pics up and give some updates soooon!!!!!
Sublimejoe
Post by Sublimejoe »
Looks awesome!
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
jessman1942
Well im back sorry its been a while been really busy with life and had to put my car on hold for a bit but anyways im back to it check it out i pulled the manifold off and installed my 22t engine harness
starting a pile of parts i wont be needing
Their wasn't a lot of space in this little garage. Im gonna have to get my car out of here soon only have so much time.
jessman1942
i was also under the impression these motors came with a td05 guess not iv never heard of a VF8
jessman1942
Moving on i got everything back together and got my new trans and the motor in the car with the help of some friends
jessman1942
and my car is now out of the garage and in my front yard it took some time for me to get everything back together on this thing
jessman1942
i was having trouble figuring out where everything needs to go my car is now running but not very well im kind of guessing here where these all need to go lol don't hate im trying to figure it out
jessman1942
Thanks for the vacuum line diagram Legacy777 it really helped their just alot of different stuff from the 22t the the 20g
Glad your making progress.
That was Vikash's diagram...and yes it's very helpful!
PhyrraM
Post by PhyrraM »
The two bolts for each coil and the VF8 indicate that this is NOT a '93-'96 Impreza WRX or Forester motor as indicated by the eBay title above. It is a '89-'93 Legacy RS 5-speed motor. The VF8 indicates it's from a manual trans car (VF10 would be an automatic)
This motor uses the stub-rocker HLA setup, and NOT the newer and more commonly discussed cam-over-bucket setups. Also the valve cover gasket is specific to early Legacy EJ20Gs and does not have a USDM equivalent.
The good news is that while virtually all Impreza/Forester EJ20Gs were open deck motors, there is a decent chance (say about 30%) that this could be a closed deck motor. I can't tell 100% from your pics, but I'm leaning towards thinking yours is a closed deck. The power potential for street use is about the same as the newer EJ20Gs too. It's a good motor, I've used and abused mine and it's still going strong. I have a write-up on getting rid of the valvetrain ticking if yours does it.
Car looks good, the red is a nice, but rare, color.
