Does the IAC valve have coolant lines running to it like on the Subarus? If so, maybe the temp sensitive metal strip in there has gone wonky.
Use starting fluid vs. brake cleaner.
Intermittent Violent Shaking Idle On Cold Start - Geo Metro
Re: Intermittent Violent Shaking Idle On Cold Start - Geo Me
I'll have to check. Not sure where the iac is. Thanks I'll have to buy some starter fluid.
