Legacy 92 turbo wont start after put it on my garage
Re: Legacy 92 turbo wont start after put it on my garage
I know I'm late to the party, but did you figure out the clicking noise from under the dash?
If not, do you have the green diagnostic connectors connected? If you do, disconnect them.
yazmo
Post by yazmo »
no i dint find out yet.
l dint have the time to removing the dash yet, but ill check for the green wire
it is a possibility maybe one of my friend who check the car have plug it
imma check this in the next two day
thx for the info!
Yeah, check for the green diagnostic connectors under the dash.
yazmo
Post by yazmo »
hey guy, first of all thx you for your effort for helping me in this process.
car run fine, beside the light flashing and all the dash light flashing as well,
when the car run the stop blinking, i have try to check for the green wire for finding the ecu code
I swear i look everywhere without finding them, ill look harder i guess
Unless i need to remove carpet, i could not find it, i saw something like it, but there were blue color on the passenger side.
check engine is on and i can hear a relay clicking alone with every single blinking light "every second"
inside tge dash near column streering clicking, eventually ill look into it.
ill never say it enough this forums is the best forums, i also own a forester 2004 xt and there forum is far from being helpful as this one.
so once again thx you so much
yazmo
Check on the right side of the steering wheel as well. On some of the post-face lift cars the green diagnostic connectors are located there.
