How does she drive now with the new ecu setup? I've ran both the revtronix and the robtune, the Rev got better fuel economy, but was temperamental to say the least.
Josh Colombo wrote: Mon Jan 14, 2002 10:23 am
Wait....I'm confused now.
I am pretty ignorant when it comes to ecu stuff. I can bolt/ unbolt and swap parts and follow write ups but I don't have much knowledge in electronics department. I can say swapping the ecu has increased the rev limiter and changed the parameters to make more power. Definitely an improvement from stock but I do seem to be having an issue.
Grabbing parts for N/A lift (aka The Green Turd) and picked up 5 speed tranny, driveline, rear diff with 4:11 and pedal assembly. Local pick n pull doesn't have much for selection. Going to try to do a swap. Think I blew a head gasket so I have to pull the engine anyway.
So, after swapping outback struts, front and rear cross member spacers and transmission member (on the Green Turd), I was having issues with the drive line rubbing at rear cross member for diff due to angle caused by lowering tranny. I ended up climbing under and building spacers for just about everything connected to the subframe.
After three years of checking local wrecking yards, a tleg came up. Someone got the short block before me but I got heads, manifolds, turbo, waterpump, wire harness, ecu, etc.... Should have grabbed the crossmember; went back for it but was already gone. Unburied the engine from the old parts car and got busy. Let's see how the Green Turd likes it.
Also, I finally hurt the white SS. Wastegate piping came off while ripping around and now she's smoking...bad.
It was at pullapart on steel street months ago. Long gone now. I got there mid-day the day after it arrived. Later found out on facebook, some dude in Olympia got the block.
I love boost even if it's from a vf11 Still missing a passenger fender. Drove to Tumwater the other day to look at one but it was really rough. Now I can tear down the ej22T.
Saw another tleg in Lakewood; looked like it had prefaclift conversion. Can't remember the color of the body but I believe the hood and fenders were wine. I should have followed him to say what up!
Tleg still sits in the garage. Did a compression test and found cylinder 4 is @ 0.
The GreenTurd is still rippin and a tearin. Put a tmic on and found some Outback tires.
Also bought another Tleg. All stock. Wine color.
Get in the trunk with a flashlight and have someone use a garden hose to run water over everything. You should find the leak that way. Just make sure that someone is going to let you back out of the trunk.
I had the same issue, turns out it was the seal on the spoler - it was shot . I just removed the spoiler cleaner up the rust & debris replaced seal with clear bathroom sealant.
Finally pulled the engine. #4 cylinder looks like it melted. Bought a parts car in the fall to swap engines but the parts car is pretty cool and I can't bring myself to salvage it.
Been working on it! Haven't uploaded in a while. Stripped the Turd. Ended up running low on oil and the crank didn't like that.
Found a touring wagon with a 5 speed swap already done. Bought it for parts but now it's pretty much my daily.
