Page 2 of 2
Re: Single Diaphragm Brake Booster Upgrade Write-Up
Posted: Sat Aug 06, 2016 2:24 am
by Alphius
My experiences were stock-ish vs stock-ish. Rubber lines, sliding calipers, parts store pads.
Posted: Mon Aug 08, 2016 5:23 pm
I drove the Legacy this weekend....it's been a while since I drove it and paid extra attention to the braking. The pedal travel definitely is less. However I didn't think I had to use more leg/foot effort to get the same braking effort out of the car. I would say though that since the travel is less the modulation of braking might be a little more difficult. Again, I think brake pedal feel is heavily subjective and comes down a lot to personal preference.
Posted: Mon Aug 08, 2016 6:56 pm
by mike-tracy
When will you be up in Wa again Josh? I don't think you've driven a stock 22t with a td05 & robtune, have you? Maybe we can setup a "Drive and compare my legacy" day
Posted: Tue Aug 09, 2016 6:32 pm
I'll be up 9/14 - 9/18 for my niece and nephew's birthdays. I don't want to plan too much so I can spend time with them, but I should be able to make time for a drive and compare.
Posted: Thu Jul 20, 2017 7:11 pm
by subiedoutlegacy
Kimo for the Master cylinder brace do you think it would be possible to install it without removal of the master cylinder?
I upgraded to 4 pot 2 pot and still feel that the brakes are lacking on feel.
I plan to put stainless steel lines on soon but have been dying to see if I can put a Master cylinder brace on, it made such a difference on my WRX!!
Posted: Fri Jul 28, 2017 5:43 pm
In general you should be able to get the brace on without removing the master cylinder. There may be certain braces that fit better than others so it may not be a one size fits all type of thing.
