Re: Parting Out 92 Legacy SS Auto
Posted: Wed May 22, 2019 11:23 pm
CRAP - i just realized this whole big theory of the universe thing i wrote a couple of nites ago never made it onto the board. It was pretty late and i must have been half asleep by the time i finished. This will teach me - AGAIN - to always back up with a copy somewhere till i know i'm good. I will try to recreate it again from memory, which may be the silver lining since i see now i gave some wrong info. Interested parties try to hang with me while i tackle this, it's kind of dry.
The ebay coolant reservoir tank CAP part number 45153AA000, and stated superseded part number 45153AA010, are not supported by the factory parts manual as an applicable cap for the BC-BF turbo cars.
The ebay cap part number 45153AA000 in the parts manual is given as APPLICABLE for all BC-BF MY 90 cars, EXCEPT the turbo and right hand drive cars. (there were no 90 MY turbo cars).
The ebay shown superseded part number 45153AA010, is given in the manual as only applicable for "L" and "LS" trim for SOME MY 93 and all MY 94 cars.
The Subaru parts manual only shows 45153AA001 as the applicable tank cap, on a separate page for Manual Trans turbo cars, and another separate page for Auto Trans turbo cars.
45153AA001 is also given in the manual as an applicable cap for MY 91, 92 and SOME 93 "L" and "LS" trim autos, and all right hand drive cars.
I may be leaving some trim cars out, but that is the meat off the cap.
So why should caps be different anyway? You would think a stupid cap would be the same across the board right? You might be thinking wrong.
First off, like the caps, the coolant reservoir tanks are not all the same.
The tank part numbers are 45151AA000, 45151AA001 and 45151AA060 for all the diff Model Year cars EXCEPT the turbo cars.
The tank for ALL the turbo cars is 45151AA040, given ONLY on the two separate parts manual pages reserved for the turbo manual trans, and turbo auto trans coolant systems !!!
OK maybe there is some difference in plumbing and fittings to accommodate the induced coolant temperature flow in and out of that little coolant filler tank on top of the turbo cars. Or maybe a tighter fitting cap due to higher pressure created in the lines open to that little filler tank, or.....??? (your guess here)
But let me give you an example of unexpected weirdness i ran into while on an expedition to figure out the Turbo Legacy power antenna, written up somewhere else on this site. You would think a power antenna mast is the same across all model years, and trim levels right? Again you would think wrong.
The BC sedan radio is a Motorola and the BF wagon radio is a Panasonic.
The sedan radio power antenna assembly is given as one part number, and includes the motor and mast.
The wagon came a year after the sedan and the radio power antenna assembly consists of two part numbers; the motor assembly and the mast assembly, and is from a different supplier than the one for the sedan.
The sedan motor / mast assembly uses a mast with a toothed cable for the motor take up reel.
The wagon uses a mast with a smooth cable with a little ball on the end that catches a notch in the motor take up reel, and is not interchangeable with the sedan motor.
Unexpected weirdness can strike at any time from any direction when you think you know how things work.
I learned all that the hard way !
Just sayin'...
Just sayin'...
