Im wondering how well the whiteline roll centre kit worked out for you? I like as much steering feel as possible. Also, which aluminum control arms did you end up buying? Ive seen a little conflicting info on whats the right length and what isnt.
Reson im asking is because im pulling the trans next week for a new clutch install. Figured while im under there with the ball joints halfway out already, i might as well upgrade all that while im under the car before the snow starts to hit for the year.
91Legacyresto wrote:Im wondering how well the whiteline roll centre kit worked out for you? I like as much steering feel as possible. Also, which aluminum control arms did you end up buying? Ive seen a little conflicting info on whats the right length and what isnt.
Sent from my SM-N975U using Tapatalk
The roll center kit actually made it feel a lot smoother cornering, and as for control arms I used a set of 96 Gc8 that were identical dimensions.
