Joe's 93 RHD Legacy Wagon Build
marsh27
Re: Joe's 93 RHD Legacy Wagon Build
Post by marsh27 »
Jdm sti strut bar? I need
93 fwd beater wagon
93 tw build in progress
Sublimejoe
Post by Sublimejoe »
Yessir!
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
Sublimejoe
Clutch and flywheel will be here tomorrow! I still need to order the timing belt kit but I don't want to spend $200. I also need to order valve cover gaskets, plugs and wires.
Parts Needed:
Manual Cluster
If $$ is tight, you can go to a wrecking yard and tear apart some timing covers and find good idler pulleys. I think autozone charges around 40 bucks for a belt. That'd be a lot less than 200.
Sent from my SM-N920T using Tapatalk
Sublimejoe
I just hate spending money. My clutch kit came yesterday but was missing flywheel, emailed the seller.
Parts Needed:
Manual Cluster
Sublimejoe
Damn I haven't updated in so long! I got super busy with work and traveling, plus it's been so ******* cold in VA until like two weeks ago.
I haven't done much really, but I cleaned my motor up and painted some pieces. I need to put the fuel lines back on still:
I also finally took the time to put my new clutch and flywheel on:
It looks like a car, and one day soon I will put that motor in.
I was visited by an old friend who held te37s perfect for test fitting, and I could not say no:
Parts Needed:
Manual Cluster
Sublimejoe
Parts Needed:
Manual Cluster
Sublimejoe
The install process was pretty straightforward, as expected. The trickiest part was getting everything lined up. Total time spent actually working was less than an hour to get it all bolted together. This includes many breaks.
Here is a more close up photo of the final resting place of señor ej20k. That is until it is strewn across the junkyard floor.
Nips over Its
I made this last night. Insane!
Parts Needed:
Manual Cluster
ride_child
Post by ride_child »
ill have to give nips a shot and report back!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
Sublimejoe
Oh man, you won't be sorry! I always thought 'its' were the way, but nips are king!
Parts Needed:
Manual Cluster
Sublimejoe
I took a bunch of photos today so I could try to figure out what plug goes where, and what will need to be merged. If anyone wants to help me identity these things it would be much appreciated!
These came with my EJ20k:
These are part of the OEM harness:
Parts Needed:
Manual Cluster
Sublimejoe
1. To Body Harness?
2. To Body Harness?
3.
4. to injector?
5. to injector?
6
7.
8. to injector?
9. to injector?
10
11
12
13
14
15.
16.
17.
Parts Needed:
Manual Cluster
ride_child
11 12 look like the other injectors
14 might be the cts
15 16 look like the knock and coolant gauge sensor
17 looks like the ignitor
Kris
'91 Black SS - SOLD
Sublimejoe
I had some time today so I started putting brackets & hoses back on. I am going to need a bunch of vacuum lines for sure.
Parts Needed:
Manual Cluster
Can you take a very high res. photo of the harness and looking directly into the connectors? I don't think what you have labeled so far is 100% correct.
Sublimejoe
I sure can! I will go do that now, was looking for a reason to stop working and go outside anyway.
Parts Needed:
Manual Cluster
Sublimejoe
Here is a gallery for you. I can organize it better when I get to my computer later
https://www.icloud.com/sharedalbum/#B0xGFssfGGBiI1h
Parts Needed:
Manual Cluster
Thanks Joe.
Can you take a high res of the harness laid out; an overall like the one below and then maybe closer sections of the harness? Also, can you label the high res individual photos you took with the number scheme so I can tie what goes where on the harness?
http://i.imgur.com/lIaqkN1h.jpg
Sublimejoe
Yessir! I'll do that right now, thanks!
Parts Needed:
Manual Cluster
Sublimejoe
I picked up some ignition coils over the weekend. Thanks to my homie Paul!
Parts Needed:
Manual Cluster
Sublimejoe
I swear I already posted this but oh well. I decided that I am going with iWire for a harness.
It is certainly expensive, but not prohibitively so; The cost of the conversion itself is $850, plus $110 for auto to manual wiring. I also have to provide an uncut v4 STI bulkhead harness, from a 97/98 JDM STI. I of course do not have this laying around so I need to either find one for sale somewhere, or purchase from iWire at the cost of $550. I then have to remove my bulkhead harness and send to iWire.
Cliff Notes: Someone find me a V4 STI bulkhead harness, and gain my eternal love.
Parts Needed:
Manual Cluster
ride_child
you have 420 posts.... haha!
Kris
'91 Black SS - SOLD
Sublimejoe
Smoked it cause I had it!!!
Sad that this ruined my post count. :(
Parts Needed:
Manual Cluster
Sublimejoe
Someone help me!
(with a harness)
Parts Needed:
Manual Cluster
subiedoutlegacy
Post by subiedoutlegacy »
:-D This build looks amazing hope you find the harness soon!!
91 Mica Ruby Legacy Sport 550 Robtune
94 White Pearl Legacy L SOLD
04 San Remo Red Impreza WRX
04 Java Black Pearl Impreza STI
94 Crimson Pearl Legacy Sport Partout
