300 WHP is my goal too, but I'll likely miss it because I'm using a standard early WRX TD05 to start.smh0101 wrote: 257 case - have cool
2008 STi Crank... the Nitride treated one (PN 12200AA400) - $300 at my cost sure yours is damaged? might not need it.
Eagles and Wisecos - $800 (sticking w/ my 9.1:1 CRtoo much fun) again, check whats damaged first. from your description you won't need pistons, and the rod should be an easy recon job
ACL Bearings - $150 of course
257 HG - $70
Misc Gaskets - $100 (have tons of new gaskets already)
ej25d heads - haveHow does it breath up high with the EJ25?
ej20r Cams - Picking up. trading for them check that your springs are good for the cams, should be OK though
Shims - $16-140 depending on what I need.
08 STi Oil Pump - $110 Why? No AVCS, so unless your bearings are clearanced wide open it's too much oil. That pump is meant for dual AVCS. No oil squirters, so a 10mm pump should do it, 11 for safety. The 12mm pump will likely just heat and aerate the oil
08 STi Water Pump - $140
Oil Cooler- Came on my 20g
Clean, clean, clean if any bearings look bad. Metal likes to hide in the cooler.
V2 STi 20g Manifold Wrinkle Black - Have Your manifold looks nice, nice call on the paint
480cc Yellow Top Injectors - Have Are those big enough for the EJ25?
EVO III 16g - $400 (know a friend who has one) no comment, never researched that one. Using the WRX turbine housing I assume?
Link G3 ECU - $1000 (probably buying w/ from my renters insurance coverage of the stolen items from my car) Renters insurance covers that! cool!
shooting for a reliable 300atw I think you'll need at least 550cc injectors
Good luck getting her all back together! You only really mention the motor and trans, did they screw up anything asthetic or suspension?
