RckyMtnLegacy's 93 Turbo...On the Road Finally!
Re: RckyMtnLegacy's 93 Turbo...EJ20G swap in progress!!
Looks right to me
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
carbon fiber hood ordered.
That's awesome! I really wanted a cf hood, but am currently preface-swapping my 92.
Looks nice!
Jonah
92 legacy wagon N/A 5MT
93 legacy sedan 25th anniversary edition 02 wrx swap ver 2 jdm 5MT
93 legacy TW 25th anniversary edition 4EAT stock with supporting mods
94 legacy TW 4EAT built ej22t vf-34 CES exhuast
I gained some wiring confidence so I got back at it. Plus I added a swamp cooler so I could work in the heat.
Time to work under the dash now. Where is the B15 connector?
Yeah you did! You need ej25d fuel rails. The ej20g rails won't accommodate the yellow tops, only grays and 22t stock pinks.
Well shit
Decided to finish other items until I find rails
Belt on and accessories getting there. Totally took apart the intake and hoses years ago so I have no idea where they go or what goes under/top of intake. If anyone has pics or advise I need help
Finished all COP engine bay wiring
Getting intake put together but can't remember where everything goes. Does anyone have pics of under the intake? I have been going through a bunch of build threads and have a lot figured out. There is a plastic line that goes under but it looks like mine is busted, where does it route to and from I may just make my own
Ill try and take some pics of my ej20g manifold this evening.
Any help is appreciated not sure where coolant lines go and vac lines. I have the ej22t vac sketch I'll try to use to
Coolant line bolts to the block, with the same bolts that bolt in the crossover pipe. Vac lines... Only vac lines of concern are the purge lines, and the line down to the fuel px regulator. Also on the last pic you posted of the engine, looks like you don't have the two pipes coming up from the water pump, that go behind the cambelt.
Oops, I forgot to get you a pic. Ill get you one tonite
http://s176.photobucket.com/user/mike-t ... g%20intake
Here's a link to the pics I took. The red manifold in the pictures has it's factory PCV lines installed, and the 3rd pic includes the pcv setup from another ej20g manifold.
Is the pcv the hard plastic line? I assume runs from the valve to the the lthe top of each valve cover. I must have broken it. Is there a USDM equivalent?
Thank you for the pics!!
Yes, the under manifold pcv line is hard plastic, and transitions to moulded rubber which go to each valve cover, and port on the back of the engine, and the pcv valve.
No USDM equivalent. What I would do (and did, on my 22t build) is use bulk pcv hose and T's to tie everything together like stock. Not as tidy as OEM, but the factory hoses are almost unobtanium, and $$$ if they are still stocked.
Getting somewhere! Went to the yard today and found a 2nd gen intake on the ground just for me to take it's fuel rails.
Where does this hose from the left side of the iac go
Where does the brake booster line go on this intake?
For the PCV lines I found a 3rd gen outback and stole its line plus the 22t line on the back of the block to see if I can get it to work
Couple more questions
Where to these need to attach to?
Oh and thank you all for help and pics. I loaded up my iPad with a bunch of your build threads to help route these lines
Few updates
Didn't make my latest deadline or 9/10 for Rocky mountain subaru fest but was able to give my parking spot in the show to a fellow first gen.
Used the show for inspiration
Turbo installed
Wiring figured out for 5 speed swap I hope
New radiator
New shifter parts and shifter installed
Apexi intake installed
New glass
Turbo installed
New radiator
New glass
Deleted since pics don't work on this comment box
Last edited by RckyMtnLegacy on Fri Sep 23, 2016 4:48 am, edited 2 times in total.
