Tony's 91 SS 29Dec R.I.P.
Re: Tony's 91 SS 12Dec EJ20ECU running rich
That code comes up in active code check mode, or are you saying it pops up as a stored code when you turn the key on
Swapping the MAF's is really the easiest thing to do at this point. If it doesn't help, then I'd dig into verifying the wiring.
Post by SILINC3R »
Got it fixed! When I ripped out my Apexi boxes I accidentally cut pin/wire9 on B48. Connected it and BiNGO!!!
Thanks again to all you guys. Would have been to stubborn to check. It's always the stupid things just as i thought.
Videos to come.
Re: Tony's 91 SS 12Dec running srong
Post by SILINC3R »
Well, believe it or not. I started working on the car again. Turbo is out and putting the stock air intake system back in. Why, because the PCV lines were giving me an issue and not seating on the rear port on the block. Also with the new MAF, I couldn't run my short ram system I had previously. I want this car to run right and not leak shit everywhere so here I go again. Also found a coolant line that was leaking which would explain the coolant on the block and why it was mysteriously loosing fluid. AND, I kind of relocated the purge control solenoid.
I will post pics hopefully if it is finished tomorrow so we can finally get a clean solution to this problem. Of course it will never be good enough nd I am sure there will be one finally attempt if I ever have to pull the motor.
Post by SILINC3R »
Got the Nardi wheel on and the hoses how I want them for now. Need to get some more clamps. Also retuned the AVC-r, pulls nice to 1.10 Bar
Got the BOV situated for now but I would like to come up with something different. Wish I had a welder.
And here we go the 3 major phase of what the engine bay has been
Post by SILINC3R »
New Video Yeaaa!!!!!
Watch Me!!!!!!!!
Re: Tony's 91 SS 20Dec New Video
Tony,
Sounds mean!
It has a pretty agressive popping/burble on deceleration.
Sounds really good, Tony!
Isn't the Nardi wheel great?
Post by SILINC3R »
Thanks Gents. I'll probably put the regualr exhaust back on when I get some more funds. Maybe throw in a high flow cat to be nice to Mother Nature.
And yes I love the wheel more than the previous one. Very fitting in my opinion. Classy yet sporty
Do NOT use a high flow cat!!! Didn't you see what happened to Mine? It melted and clogged inside entirely choking the Shit out of my engine and then blew a large chunk out and lodged in my muffler tip melting my bumper. Don't you do it man. They're garbage.
Is this video open downpipe? Sounds exactly like when I didn't have an exhaust after my down pipe.
Post by SILINC3R »
kimokalihi wrote:Do NOT use a high flow cat!!! Didn't you see what happened to Mine? It melted and clogged inside entirely choking the Shit out of my engine and then blew a large chunk out and lodged in my muffler tip melting my bumper. Don't you do it man. They're garbage.
I have an open cat then straight piped to the bumper. I had my mic next to the exhaust which is why it is so load. So no cat at huh haha.
Kimo,
I think your cat problem was related to the specific brand or you got a fluke bad one. What brand did you have?
I've got a magnalfow "performance" catalytic converter that's been on my car since 2005 without any issues. So I don't think you can say "all" high flow catalytic converters are bad.
Maybe not but it's not something I'd try again. Was trying to be "green" and it screwed me. I'll look for it on summitracing. It was a cheap one I think it was only $40. Fair warning.
Well I figured out why I couldn't find it on summit. Searched my build journal and it seems I got it from eBay. $40 with a 5 year warranty that I didn't register for.
http://bbs.legacycentral.org/viewtopic. ... &start=100
Didn't find any information on it though.
Yeah, that's quite a bit smaller than the cat in my car.
I like the symbology of your pic, Kimo
93Leg-c
Post by 93Leg-c »
Kimo, that isn't a metallic substrate cat, is it? Or, should I say "was it"? :)
'94 TW
Post by SILINC3R »
I'm so confused
I don't know. Don't know much about cats.
SILINC3R wrote:I'm so confused
What is the other object in Kimos pic?
A haha haha I get it now!!!
Post by SILINC3R »
Got it now, thanks haha
Post by SILINC3R »
Well, so this happened. :cry: :yuck:
Little Subaru gave its life for me.
93Leg-c
Re: Tony's 91 SS 29Dec R.I.P.
Post by 93Leg-c »
OUCH!!! How are you doing? I'm glad you're alive! But you must be hurting from that impact! Such a beautiful car, and yes, gave its life for you!
Reminds me of how my Legacy protected me as it got totaled.
'94 TW
