RckyMtnLegacy's 93 Turbo...On the Road Finally!
Sublimejoe
Re: RckyMtnLegacy's 93 Turbo...EJ20G swap in progress!!
Post by Sublimejoe »
The more expensive one doesn't have a tranny at all though hahahaha
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
The Forester "ej20g" is an ej20k with a different name. It has 9:1 compression and different electronics & sensors and connectors than an ej20g. An ej20g intake manifold bolts on, so it would be an easy swap, but.... The robtune doesn't support it due to the high compression. Ej20k (and Forester) have a centered coil pack on the intake manifold.
As to why the wrx ej20g engine is pretty cheap, my best guess is the majority of swappers have moved on to ej205/7's and ebay sellers just want rid of their old inventory? Why doesn't everyone sell em cheap, that is the question.
Sublimejoe
Awesome thanks!! Can it be converted to coil on plug, as opposed to replacing the intake manifold?
Parts Needed:
Manual Cluster
Oh yeah, the ej20k/ej20g heads are set up for COP, no issue there. Did I miss it and you are going standalone?
Sublimejoe
Nah you didn't miss anything, I hadn't planned on going standalone unless I have to. I want to do whatever makes the most sense, cost and time wise.
Parts Needed:
Manual Cluster
Ah ok. The ej20k engines are better, but not by enough to justify buying them when you already have ej20g.
Sublimejoe
Ok cool. I currently have no motor, so I guess it could go either way based on what I can find locally?
Parts Needed:
Manual Cluster
Sublimejoe wrote:Ok cool. I currently have no motor, so I guess it could go either way based on what I can find locally?
Here's my thoughts on this: the ej20k (and forester ej20g) have better flowing heads. The intake manifold is interchangeable with an ej20g one. The ej20k manifold has some cool features like under manifold turbo inlet, power steering pump with offset reservoir and other small things.
The wrx & sti ej20k engines have 8-8.5:1 compression, the forester is 9:1. Robs tune will work with the WRX & STI, but not the forester (for long). The ej20k/forester ej20g ecus won't work with our cars at all, without a major wiring harness merge.
The problem with using the ej20k manifold is its electronics don't work with ej20g or ej22t harnesses. You can't swap the IACV or TPS/ throttle body over easily, but it can be done. Kimokalihi and others spent AGES coming up with a solution that involved machining spacers and flipping the throttle body 180* (so the throttle cable comes in on the opposite side).
What I would do is get either a WRX/STI ej20g or ej20k long block and use a WRX/STI EJ20g intake manifold. Our ej22t wiring harness works/plugs into the ej20g electronics without issue (some say you have to extend some wires going to the sensors on the coolant crossover pipe, but I haven't needed to do this in the 3 I've swapped).
Forgot to mention, ej20k intakes have a wierd fuel rail setup, you can't mix and match rails like you can on an ej20g/ej22t.
So to run phase II yellowtop injectors, you need a product like this:
http://www.deatschwerks.com/products/ac ... kit-detail
Otherwise, you are stuck with graytops and phase 1 yellowtops (aka 480cc's).
Sublimejoe
Damn, so much great info! Thanks so much! I'm close to pulling the trigger on the wrx one that I linked.
Parts Needed:
Manual Cluster
I lost track who's thread this was. Lets keep this one focused on Rocky Mountain's build. Apologies to the OP ;)
RckyMtnLegacy
Post by RckyMtnLegacy »
Lol, it's ok I like the attention to my thread. Still trying to bleed this clutch
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
Pntaste4evr99
Winestone Cowboy
Post by Pntaste4evr99 »
Mikes just selfish lol, jk. But I feel your pain about bleeding the clutch, I had my 10 year old "help" bleed mine, u know, the job of push the peddle down, hold, and etc. Till I realized she was only holding it half way down. Needless to say, there was a lot of brake fluid puddle afterwards...I want one of those fancy bleeders
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
My friend John has good luck with a speed bleeder in there. You know, the ones they use on brakes.
Reuben
Post by Reuben »
Btw, I'm running an EJ20K manifold, and TPS on an EJ20G loom from a 1990 GT. Simply done. You change the polarity, and adjust the angle of the sensor, the 20K TPS can matchb the range 20G ECU's require within their adjustment (both sensors are linear). The only thing you loose is the idle switch. I got around this by using an accelerator pedal with a microswitch on it, you could just as easily put a microswitch on the throttle body. But why would anyone want to do this? Throttle size of course, EJ20K throttle bodies are huge.
RckyMtnLegacy
No updated since I have been getting ready for my trip. Headed to Tokyo in 2 days. Trying to see if I can get to Up Garage but doubt I'll have time.
Tokyo, nice! How long will you be there? I've seen the inside of Narita airport but never made it outside.
RckyMtnLegacy
1 week
mike-tracy wrote:
Legacy777 wrote:Here is the injector calibration from my yellow "sti" injectors. There is a column with IDC's on it, but I don't see that specifically related to flows.
https://main.experiencetherave.com/suba ... _calib.pdf
Are those the ej20k style or GD impreza STI Injectors, Josh?
GD Impreza STi injectors. To my remembrance they came from a 2004 STi
RckyMtnLegacy wrote:1 week
Do you have your trip planned out or are you looking for stuff to do? I've been there a couple times and was there most recently in June.
I highly recommend you check this out! You will need an international driver's permit which you can get at any AAA store. I did course B during the day. If you've been to Tokyo before course A or C at night would likely be the most fun because you'll be going through Shibuya at night where there's typically a lot of people. I tried using my gopro the video was a bit bouncy due to the vibration. They do offer body/head mounted cameras and I think that'd be better. They offer a discount in the cost if you leave a review. It was well worth the money and I'll do it again when I go back :)
http://maricar.com
If you're looking for stuff to do let me know and I can pass along some suggestions.
RckyMtnLegacy
Very cool!! Any help is much appreciated. My wife is not really into much so I get to run this trip. London and Germany was hers
RckyMtnLegacy
Just realized I don't have time to get my international drivers license to kart around Tokyo :(
Safe travels and here are some of things that I tried to do when I was there in June. If you haven't been there before definitely do the normal tourist stuff like Tokyo Tower, Shibuya, EDO museum, Akihabara (electronics meca), Toyota car museum (there's more than one, but I don't remember the specific names), and there's a robot dinner theater place that I've heard is pretty cool.
Subaru STi Museum Japan
https://www.google.com/maps/place/Japan ... 8262?hl=en
Subaru HQ
https://www.google.com/maps/place/%E5%A ... 3308?hl=en
MariCar
http://maricar.com
Tokyo Skytree Tower
https://www.google.com/maps/place/Tokyo ... 7004?hl=en
Eat big pancakes @ Ginza West
http://www.ginza-west.co.jp/english/
https://www.google.com/maps/place/Ginza ... 6669?hl=en
Gonpachi Nishi-Azabu (Kill Bill Restaurant)
https://www.google.com/maps/place/Gonpa ... 5128?hl=en
Sushi Bar Yasuda
https://www.google.com/maps/place/SUSHI ... 4101?hl=en
RckyMtnLegacy
Thank you very much! Most of those are one stop from my hotel too
Awesome! Have fun :D
