Spencer's Legacy Turbo *New Pics Page 17*
Re: Spencer's Legacy Turbo *New Turbo Page 9*
Is that my tranny you're having problems with?
Yep
when decelerating? Or like all the time.
All soobs that are a manual that I have driven or been in make weird noises when slowing in gear
Lol... Only when accelerating.
I think I'd know if it was just engine noise from Decelerating Zach LOL
Shit. That is a bummer for sure. Let me know if it turns out to be a POS and maybe I can buy it back from you or trade you the turbo back and some cash for it.
I don't want to trade you a bad tranny or one that's going to need work.
Well...
The transmission grenaded tonight... started stuttering (whole car jerking because it was locking up), so I slowed down to pull over and it siezed... completely.
Finally after I called a so called friend of mine who wouldnt answer, and the I blew up his phone because I figured I was stranded on the side of the road, answered briefly enough to yell, "I DONT WANT TO FUCKING TALK TO YOU!!" and then hung up on me, I got pissed off enough to just rev the crap out of it (oh idk... 6500 rpm?) and dump the clutch.
Car lerched, and made a nasty noise and started driving again. But stuttering really bad.
Limped it home while making terrible noises.
Then realized all my shit was still at work, so I drove it back to the office, making horrible noises.
Anybody have a turbo tranny?
That's shitty man, I can't believe that happened. I'll figure something out. Maybe I can pay for the next one if you can find one for a fair price.
Dont worry about it Kimo. Not at all
Got a tranny from doug that needed a center diff, took it apart and discoverd that it was a bad bearing on one of the shafts in the transfer case. No biggie, swapped it from one of my other trannys...
Took apart the car today, everything is ready to lift out, just gotta pick up the cherry picker tomorrow.
Should be all done tomorrow night or early tuesday morning. Back on the road again... Until I pick up another car as a daily, i'm puttin miles on the legacy fast and its time it gets some real tlc that isnt rushed.
Oh and found a REALLLLLLLY bad problem today... Front passenger wheel bearing is DESTROYED... as in, I'm amazed the wheel hasnt fallen off yet. Gonna have to replace the whole hub, i'm sure its worn a grove in it.
That's great to hear. Have you tested it out on the road yet? I still feel bad.
When I got my first legacy the guy who sold it to me told me it had a bad rear differential. He had one from the junkyard ready to go in. It was making a lot of grinding noise so I swapped it out and the problem was still there. Jacked it up and spun the wheels and found out 3 wheels had totally destroyed bearings! Haha. Guess that's what 285K miles will do to some wheel bearings. I replaced all 3 hub assemblies from a junkyard car and 1 of them was bad again. Replaced that one again and everything was gravy. Easier than replacing a bearing I'd say and only cost about $15 a piece.
Almost done...
The rain is causing constant delays. Its pissing me off!!
Everything is almost in... Engine and tranny, have to finish gettting one of the axles mated (the pin wont go through for some reason... grrr. And the shifter
Put a 10lb Flywheel on because the other was slightly fudged up... the snout on the input shaft siezed to the bearing on the stock wrx flywheel i had (why there is a bearing there I dont know). And when I forced the engine and tranny apart the bearing exploded and shot a few ball bearings around. So I swapped it with my light weight one.
Discoverd why I've hated to ej20g... the up pipe was almost totally split apart, so the turbo took forever to spool up. Replaced the uppipe and headers with my other headers and perrin up pipe.
Just gotta wrap things up once it stops raining.
Pictures?
Here are the only pics so far.
Its just about stopped raining. Going out to finish it up. Not much left to do.
Also realized that its going to zing in like a motorcycle now... Lightweight Flywheel and Lightweight Crank Pulley
I know that Ive read on here that you should do that but... I'm more down for finding out myself
Anaylze that pairing(lightweight flywheel/lightweight crank pulley) and report back your findings.
And send me those parts you knuckleheadalodian!
Sorry John... I will. I was thinking about that today.
Okay so update... Its zingy as hell... Just like a motorcycle. But there is an issue, of course there is.. Would one of Spencers projects ever just go as planned? oh hell no.
Whenever the clutch engages it gets a really nasty clanking awful noise.
Is it the tranny you say? I dont know yet. I'll find out tomorrow.
Oh man. Hopefully my 9lb flywheel is too zingy. I mean zingy like a crotchrocket sounds great but I doubt it's THAT great.
Well its only like that when your sitting still at a light and are reving it in nuetral.
But I'm much more concerned with the terrible noise.
Everything done... Noise was the pilot bearing... Long Story short... I pulled the engine again, fixed the pilot bearing issue, and put it back together. All well and good.
Zingy as HELL... Like a motorcycle. Its much quieter without a separated up pipe. Also... The turbo actually spools!!!! Yay for boost!!! I might not actually hate the ej20g now LOL
Nope... Dont HATE the 20g now... Not as powerful as the 2.5l but still fun to drive... Handed it to a WRX today
douglas vincent
Thanks for letting know about the tranny dude.... I will call you names to your face.
Haha.. sorry..
I'll call you tomorrow...errr... today... and figure out when to bring back your cherry picker
thank you by the way!
I've just been reallly busy getting back to work and well... yea.
92ss satinsvoice
well well well... holyfuckincrazyassshitdamnfuckintheaves! i just got done reading your thread dude. i didnt know that your car has been sutch a bitch to you, really sucks. at least you get to drive your beast while mine sits cause im so broke all the timel. well best of luck dude! let me know when you go to WCSS. i might just have to ride with you cause im not driving my shitty silver turbo to get laughed at...lol
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
94 L n/a 5spd, Rip
I done did it... Killed the ej20g.
2500rpm, 2nd gear, half throttle... Pop Bang Clang Grhalkjrlksajdflkjsadhfuksdaf
Silence
Wont even turn over... Me thinks broken rod and siezed motor. EJ20G FAIL
Silence
Sorry to hear that Spencer.
How far away were you on the original motor build?
Honestly I never even got started on it
