86 Subaru Leone
NICO
Re: 1986 Subaru GL-10 Leone TURBO
Post by NICO »
GL-10_madness wrote:hey i am very curious where you got your parts catalog for the late model leones. I have an 86 gl-10 wagon that is going through a make over after hitting a deer and I am interested in the way you made your rad support bolt on. Please let me know how to find all the parts i desperatly want!!
love your name reminds me of my build how madness I made & to find the parts for it alone..
most of my parts are from my dealership in canada, if they dont got it then I use USA subaru. if they dont got it then japan suabru. if they dont got it then I am out of luck...
I have a buddy in japan that can get me the rare used cool stuff you see in my build for my car..
for the rad support I am pretty sure I own the last one ever made from Subaru Canada/USA/JAPAN...
where is your location ?
Legacy777 wrote:Yeah, those are cool fogs!
So what happen with the guard rail?
tried to brake to avoid hitting someone then grove in the road next to guard rail sucked me in and tapped it... big mess self inflicted pain lol..
SILINC3R wrote:Damn son, love this car. And I want those fogs!
i wish i had more room on the front bumper to put them on.. intercooler is a monster.. I am trying a new front bumper which is the japanese one or early usa one so ill have more room all around up front for them..
car is back up and running, oil cooler and brz rad are working very well with the new set up. its time to get it out on the track before winter comes.
Looking good Nico!
10wrxing
Post by 10wrxing »
Nico,
Are those pics taken on HWY 25?
Saw the car at Hypermeet.
Looks amazing!
Tbly89
Post by Tbly89 »
Beautiful car! Nice work man!!
NICO
Re: 86 Subaru Leone
Post by NICO »
so decided to improve the handling of the car a bit better and I noticed the 2015 uses rear spherical bearings. I had a machine shop shave them down each side 1.5mm and made a spacer to take up the slack for pressing them in my lower suspension mount in the rear of my coil overs
locally I found a nice set of ES-Tarmac ENKEI wheels 5x100 16x8 et45 14lbs wheels, super light weight compared to my braid wheels
started to build the spare motor, Ej22T stock crank, 10mm oil pump, ACL bearings, Carrillo Rods, Wiseco pistons, cometic head gaskets, ARP Custom Age 625+, V9 STi heads, killer b pick up, and allot of new factory case bolts and plugs gaskets
CFK
Re: 86 Subaru Leone
Post by CFK »
Damn Dude, Lookin Good :!: :smt007
with my luck I need a Fully Built set-up waiting in the garage. Pretty sure the plastic speedo cable in my freshly built tranny is toast :smt089
Your always Pushing, Very Inspiring :!:
Not on Instagram anymore :?:
Build Thread : HERE
92 SS 5MT. Project Daily
84 Jetta Coupe. Real Project
99 A4 Avant. Wife's Daily
NICO
Re: 86 Subaru Leone
Post by NICO »
CFK wrote:Damn Dude, Lookin Good :!: :smt007
did you ever get yours working again ?.. did you rebuild the 5mt ?
ya no more insta boring to me I guess...
so this is what else I'm working on at the moment along with the lower pillow ball bushing for my coil overs, I decided to get a one piece unit made so I can get rid of the rubber spacers and all that mess..
this is a prototype unit to test on the car then i can get them made up once it fits ok.
black is 80s strut mount, green is coil over mount.. needs a bit more work to be perfect fit
also found the rear garnish in japan for my car, maybe ill put it on. to many holes to drill in a clean car.
CFK
Re: 86 Subaru Leone
Post by CFK »
Ya, I got it back on the road since then. Then the TB Slipped A few Teeth, back on the road for a few 100 Kms. Now it appears that the plastic speedo gear inside the tranny is stripped. Got the tranny rebuilt probably 10-12000 Kms ago.
️Not impressed. As you know. It never ends :!:
:smt089 p
Build Thread : HERE
NICO
Re: 86 Subaru Leone
Post by NICO »
CFK wrote:Ya, I got it back on the road since then. Then the TB Slipped A few Teeth, back on the road for a few 100 Kms. Now it appears that the plastic speedo gear inside the tranny is stripped. Got the tranny rebuilt probably 10-12000 Kms ago.
:smt089 p
dammm.. hate when it breaks after all the work is done. thats why no more messing around for me do it all at once fix everything and pray lol..
subaru 80's old meets subaru 2012 new moulded into one...
cnc billet aluminium & anodized black, now I can add a pillow ball at the top mount like the front..
next project is cnc billet aluminium front control arms with pillow ball and 1' longer so I can get some larger cv axles to with stand the abuse I am about to put down. cv axles will be new age subaru length.
NICO
Re: 86 Subaru Leone
Post by NICO »
so this is my rear top hats bolted up with spherical bearings.. the lower cups also have 2015 STi spherical bearings made buy subaru which I needed to make a spacer.
I decide to get serious with my coil-overs to make this car handle like a top notch missile and I got the GR STi Ohlins road & track set.. I have to do two mod's to make them fit perfect which is the lower rear bushing mount will be made new with a STi spherical bearing and drill the front top plates to early subaru size like leone/gc8. my reactions from just holding the ohlins is how light weight they are WOW half the weight of my hsd..
like to thank jake @ ohlins usa for hooking me up with the extend clickers also !.. there on the way.
Re: 86 Subaru Leone
Nico,
That's some good car porn you have there.
NICO
Re: 86 Subaru Leone
Post by NICO »
Legacy777 wrote:Nico,
lol... expensive also haha they better live to the hype
so here they are, my very own aluminium control arms like the big boy STi have. now the little Leone can be up to STi spec !
But the little Leone has 1up on the STi with the 2015 STi oem pillow ball bushing in its place :D
25mm longer so now I can run oem cv axles from a STi or those 800hp ones..
NICO
Re: 86 Subaru Leone
Post by NICO »
ohlins custom made for the Leone STi.. lower mount was machined new to be used with the oem 2015 STi pillow ball bushing.
NICO
Re: 86 Subaru Leone
Post by NICO »
so since I was making stuff I made pillow ball bushing inserts for my arms in the rear to give it that razor sharp handling...
cusco design
Porsche 911 has all most same design look rear arms and they also upgrade with pillow ball
NICO
Re: 86 Subaru Leone
Post by NICO »
new control arms on, ohlins on, pillow ball heim joint the hole car.... feels great now just need alignment..
was testing it on the track and she handles like a dream... only thing missing was a race seat to hold me.
2015 Sparco Grid.. so light weight from there old line up of seats.
STi axles now
more pictures and videos of my Leone on Insta-gram
https://instagram.com/pinocchio_ok/
NICO
Re: 86 Subaru Leone
Post by NICO »
so since I was on the track and all most lost a motor to a faulty oil pressure sensor leaking I decided to get some proper equipment to finish the system off and new sensors.
Radium fuel rails and Bosch FPR adapter to keep it nice and simple and in series on my spare Spec-c V8 STi intake manifold.
I can build the proper lines now then swap them on to my Leone
also finally finished my new front bumper... JDM/USDM mixed with Canada top trim and impact beam.. fully mutt now lol.
all done no more accidents please !!!... next to my favourite year Subaru 2015 got to get one of these
NICO
Re: 86 Subaru Leone
Post by NICO »
these are my new fuel and oil pressure sensors KAsensors and from just installing the oil pressure wow highly accurate
like to thank Franz @ Dieboldautosport for hooking me up with these bad boys !
Lilfluffynacho
Re: 86 Subaru Leone
Post by Lilfluffynacho »
What happened to your Instagram?
Dominator
Re: 86 Subaru Leone
Post by Dominator »
Great stuff Nico. I hope you're still working on it. I'm always impressed at your ingenuity, I can't wait to see what you do next.
Re: 86 Subaru Leone
Post by SILINC3R »
Lilfluffynacho wrote:What happened to your Instagram?
He broke the Instagrams!
Re: 86 Subaru Leone
SILINC3R wrote:He broke the Instagrams!
Hahaha :lol:
NICO
Re: 86 Subaru Leone
Post by NICO »
I guess I should update this build thread since new parts are being piled up for my Subaru Leone RX TURBO STi, as of now its in storage for winter but was building the Subaru Leone TURBO WRX NB-R Wagon version which can be found here --> http://forums.nasioc.com/forums/showthr ... ?t=2687011
or insta gram https://www.instagram.com/big_bad_wolf_xo/
so I just ordered these EJ22T oil jets brand new from the dealership which if I remember right they couldn't be sold at the dealership which is a myth !.. also got the JDM STi quick steering sticker for my Leone.
out of japan I finally found one of these rare STi 6mt Short shifters which was a task and has the serial number right on it from STi factory.
NICO
Re: 86 Subaru Leone
Post by NICO »
another cool part from japan R180 STi finned rear diff cover, helps cool the rear diff fluid.
Re: 86 Subaru Leone
Post by SILINC3R »
i've wondered how much these cool them down. I guess any cooling is helpful.
NICO
Re: 86 Subaru Leone
Post by NICO »
SILINC3R wrote:i've wondered how much these cool them down. I guess any cooling is helpful.
if STi made it must do something lol.. i would need to do a test but not worth the time :)
so new season and new SUPER Rare rims for that 90s style square look, these a hard to find even pictures of them !
JDM 16x8 5x100 ET35 Tecnomagnesio ..MAGNESIUM..
aluminium caps with snap rings wow !
Made In Italy
off to the walnut blasting and ready for the gold paint job !
