An ECU scan tool for turbo and NA owners
wtdash
Re: An ECU scan tool for turbo and NA owners
Post by wtdash »
Jc25 wrote:I haven't been able to make Evoscan work properly, so now I'm taking a look at B10. I dug out my old computer and it only has 15 vga connector. ( link below) I found an adapter that turns a the 15 vga connector to DB9 Female ( link below) I'm wondering if anyone know if this will work?
https://www.google.com/search?q=vga+15+ ... 80&bih=685
http://www.frys.com/product/5088875?sit ... IN_RSLT_PG
Hi,
I've used evoscan w/a '91-'94 turbo ecu, and a '96 ECU (OBD2) thru the SSM (yellow connector above right knee). Logged w/Evoscan and an LC-1 wideband a couple weeks ago on my '96 that I turbo'd.
I use a USB-Serial Cable connected to a Metra connector - search on here.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Jc25
Post by Jc25 »
I can connect to evoscan, however I'm not getting any feedback from 02 sensor and the mass air flow sensor. I'm having issue with smog here and CA, and I'm not getting any feed back from the sensor I need to see.
I'm working with subie gauges and it's picking up all the sensor. However, I'm comparing the values coming out of my multimeter and what I'm seeing on the screen and they don't seem to match up. The other problem is that it's all in German, and I have to translate everything.
wtdash
Post by wtdash »
ARe you getting an O2 and/or MAF code? And what car do you have?...You can list it in your Sig.
If your O2 is old/unknown replace it.
Td
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Screwdriver
Post by Screwdriver »
If you have o Problem with german Language at Subi Gauges, you can use Jecscan.
http://www.alcyone.org.uk/ssm/software.html
That´s a similar Software for Windows, but in English Language. It works on USB like Evoscan and Subi Gauges.
Different Virus Software shows a Warning Massage at the Software Download.
But there is no Virus inside! You can trust it.
LG Tom
1987 VW Caravelle Carat EJ22 MT
1993 Legacy EJ22 AT (Winter use only)
1995 Legacy EJ22 MT
