CJ's Prefaced 92 SS build 22T/205 Hybrid - Legawrex
Re: CJ's 92 SS build...
The middle shift rod is being a bitch.....
I dont have a way to check that :-/
I also have to swap forks and rods
Those shift rods are fun aren't they! Is this your second time messing with them?
Legacyturboguyin253 just had a shop do this for him - n/a gearset into his turbo tranny. Roopair in Tacoma.
what was the cost on that job?
I was gonna charge him undetr 500 when we talked about it.
kimokalihi wrote:Those shift rods are fun aren't they! Is this your second time messing with them?
No it's like the 3rd or 4th. I'm wondering if theres a certain order to do them. I got the left out and the right rod is ready to come out but doesnt clear the middle rod.
All that redhook when we did yours made my memory fuzzy lol
Legacy777 wrote:Yeah.....that'd be pretty sweet if you can just swap the gear sets.
One word of caution is that you need to make sure the gear back lash and end play is set properly since you putting a different set of gears in the case. Shouldn't be a big deal, but definitely needs to be checked.
Now that I think of it, since the cases are basically the same inside. The gear set has the shims necessary to space the pinion correctly in the n/a trans. Should be ok. It worked when we did Kimo's trans.
Hope for the best right?
Lol don't forget we had to swap the forks and rods along with everything else.
Drink more redhook and it'll all come back to you.
Yeah look a few posts up lol. Im bitching cuz theyre being a bitch hahaha
There are going to be slight differences in the case dimensions due to manufacturing and machining tolerances. This is why some gear sets may have 3 shims vs. 4 shims, etc. You may have just got lucky with Kimo's transmission. It may be fine, but I'd still suggest checking the gear lash on the front pinion and the end play.
cj91legss wrote:The middle shift rod is being a bitch.....
I have a dial (but no base) if you wanna borrow it.
Used a paint pen.
Drove my whip today!!
robertpaige
Post by robertpaige »
How'd it feel? Holding up decent?
I didnt rail on it. 40mph in 5th gear was kinda cool tho. Top end is gonna suck i bet.
I do need a clutch slave too. Mine is leaking.
Top end isn't gonna suck, unless you're trying to do more than 135 lol.
mike-tracy wrote:Top end isn't gonna suck, unless you're trying to do more than 135 lol.
You underestimate the CJ.
beatersubi wrote:You underestimate the CJ.
Hahaha :lol:
Ok So driving last night doing 60 at approximately 2700 rpm. That's nice.
Anyways, I started hitting fuel cut as soon as i got everything put back together. Looked at everything under the hood, and over looked everything and still could not find the culprit. Looked for hours, and decided to just hook up my stock bcs and see if that helped. No more fuel cut, Blitz settings are the same as before the transmission work. WTF EVER, i'll look at the blitz another day. But i did realize my 30 dollar prosport gauge is off, looks like i'll be replacing that as well.
Got a pretty decent set of fenders and headlights at Pick n Pull the other day. I'm officially going prefaced on my 92.
I have pre-facelift turbo hood and bumper, if you need it.
I do!!!!!! Price?
Well, Placed a bid on some JDM corner markers. Got some body panels. Getting some stuff from Stephen soon. Gonna go play with some coil packs!!
