86 Subaru Leone
originalcyn
Re: 86 Subaru Leone
Post by originalcyn »
So good. Shaping up nicely!
Kijan
1993 Legacy LS | PBM 227
Re: 86 Subaru Leone
NICO wrote: Tue Jun 04, 2019 4:09 am I can't remember where I left on but lots of new stuff and building stuff has started
also decided to construct my own shifter setup because Subaru won't sell me there version
short video of the day & night shifter feel
https://www.instagram.com/p/Bju3YLXn3op ... _copy_link
Nico,
Can you elaborate on what you did to the shifter? I see you have upgraded bushing in the joint and pivot on the lever, but is there anything else you changed?
NICO
Re: 86 Subaru Leone
Post by NICO »
originalcyn wrote: Tue Jun 04, 2019 5:15 pm So good. Shaping up nicely!
yeah so far so good, body shop this week and motor work while I wait for paint work
NICO
Re: 86 Subaru Leone
Post by NICO »
Legacy777 wrote: Tue Jun 04, 2019 6:09 pm
Nico,
instead of rubber or plastic I made brass so copy original's, then that busing I pressed in was the same size as the rear control arms from svx pillow ball and made bushing to take the slack for bolt like stock.
the tricky part is the pillow ball with race and cup to fit in the lower section of leaver. clip to hold it all together
NICO
Re: 86 Subaru Leone
Post by NICO »
well here it is ready to get sent for paint and now we are all caught up with the build thread on the wagon.
insert EJ22T ( forged built bottom end ) EJ207 STi V8 big port heads, Turbo ?? maybe ( twin scroll / single scroll ) rotated & 6MT six speed STi R180 diff.
NICO
Re: 86 Subaru Leone
Post by NICO »
many parts have come in for the motor now its time to dig a ej22t block out and build it while I wait for paint work.
Wossner Made in Germany forged 22B pistons and connecting rods, STD size pistons means no messing around with my ej22t block & machine shop 👌.... I should have just built all my ej22T this way :rolleyes:
ACL racing STD size bearings not race version, STi spec-c oil cooler adapter, proper water pump with single port and old school timing belt tensioner from the ej22t aka the motorsports racing tensioner.
aurora asm-10T military aviation spec front control arm spherical bearings, this will all me to run longer aka normal Subaru length CV axles and also camber. I won't need to modify the front crossmember to except XT6 front control arms.
lots of mess 🙆‍♂️
originalcyn
Re: 86 Subaru Leone
This reminds me of those "how to draw a thing" memes where it's just first draw a circle, then make a portrait.
Here's a table of parts, bam now we have a rad car. lol.
Thank goodness you're better at documenting things that a lot of people.
Kijan
Re: 86 Subaru Leone
I think the reason people usually go with oversize pistons is the cylinders sometimes aren't perfectly round after time. They become slightly ovaled and the boring out brings them back to basically perfect again.
Re: 86 Subaru Leone
NICO wrote: Wed Jun 05, 2019 5:12 am
Ok, thanks for the explanation.
NICO
Re: 86 Subaru Leone
Post by NICO »
originalcyn wrote: Fri Jun 07, 2019 5:29 pm This reminds me of those "how to draw a thing" memes where it's just first draw a circle, then make a portrait.
lol lol thanks
NICO
Re: 86 Subaru Leone
Post by NICO »
mike-tracy wrote: Fri Jun 07, 2019 9:46 pm I think the reason people usually go with oversize pistons is the cylinders sometimes aren't perfectly round after time. They become slightly ovaled and the boring out brings them back to basically perfect again.
yes correct, all the blocks I've owned seem to be fine over time
NICO
Re: 86 Subaru Leone
Post by NICO »
Legacy777 wrote: Sat Jun 08, 2019 9:29 pm
no problem if you make one need help let me know
NICO
Re: 86 Subaru Leone
Post by NICO »
ADDCO 22M front and rear sway bar set up for the wagon
Battery tray removed so I can slide them spark plugs in in seconds & front mount intercooler holes cut before paint work
hydraulic clutch slave holes drilled
BRZ koyo radiator fits like a glove
Re: 86 Subaru Leone
That's cool you can use BRZ parts :)
Regarding the shifter, I've been happy with mine. I used TiC's poly bushings on everything and it's very solid feeling.
NICO
Re: 86 Subaru Leone
Post by NICO »
Legacy777 wrote: Thu Jun 13, 2019 5:57 pm That's cool you can use BRZ parts :)
its like a smorgasbord in here of parts 😂
👏👏 the shifter makes the car feel so much better when you stiffen it up, so much more enjoyment for sure.
so since quarantine I've been busy in the shop.
picked up a Full Race twin scroll headers to match's my sedan set up
Borge Warner EFR 7163 takes care of the turbo with internal gated & bov
some 4 pot / 2 pot action to match the sedan set up, also got stainless steel pistons made up front and rear for thermal and rust prevention
got a personal specific torque plate made for my EJ22T blocks, proper thickness of the head was used so it match torque strengthens
torque plate results, yes it makes a difference for sure
time to assemble the wagon engine, the the spare motor for the sedan or the wagon lol
what its going to look like
can't have a new motor with out a good transmission, so I took apart my spare STi 6mt to change some synchros so its smooth like butter.
NICO
Re: 86 Subaru Leone
Post by NICO »
all primed up and ready for the single stage white paint job to match my sedan
here is the pistons I made and got wrinkle red powder coated my valve covers
so after trying to rebuild my steering rack it seems that seals are impossible to source so !
The old school Subaru guys are going to find this one interesting !
1986-93 GL-10 TURBO engine Crossmember
1991-04 New age Subaru Steering rack
what we have here is a option that I can take advantage of
18:0 GL-10 steering ratio
15:1 STI 2004 steering ratio ( my new rack is on the way 😁✌️)
Re: 86 Subaru Leone
Awesome work as usual Nico!!
NICO
Re: 86 Subaru Leone
Post by NICO »
Legacy777 wrote: Mon Apr 27, 2020 7:13 pm Awesome work as usual Nico!!
pretty sure this is the last build I do, getting to old now lol
Single Stage White 80's paint for my 88 GL-10 TURBO
NICO
Re: 86 Subaru Leone
Post by NICO »
today was exciting !. A 2004 Subaru STi Steering rack showed up, its time to install this into my old school 80s subaru engine cross member
so here is the issue, the lines need to be a little bit longer and then you move the bracket over to where the fancy factory sticker is.
take the bracket off and move the lines out the way, so there we have it, it fits right in the spot.
also we have to make it look original that's how I roll, sometimes lol !!
with the same bracket I cut out the U shape a little more, this way I can bolt it up like stock. then I flipped the bracket around so I can put the bolt on the top, this makes it easier to install.
you have to bend the lines into place for a little length which you can do by hand.
Ps: you have to enlarge the holes on the crossmember beforehand, and then cut the pocket out on the opposing side so the lines can stick out
what I gained from doing this
18:0 GL-10 Steering ratio to a impressive 15:1 04 STi Ratio, that's 4 ratios quicker. id say that's more impressive then everyone only upgrading from 15:0 to 13:0 (3 ratios )
Re: 86 Subaru Leone
NICO wrote: Wed Apr 29, 2020 3:47 am
:lol: :lol: I hear you on that one ;)
Re: 86 Subaru Leone
Post by entirelyturbo »
I'm gonna be the one to derail the conversation about Subarus and ask about that yellow M100 Lotus Elan in the background of one of those pictures ;-)
*Formerly DerFahrer*
Re: 86 Subaru Leone
DerFahrer wrote: Fri May 08, 2020 4:59 am I'm gonna be the one to derail the conversation about Subarus and ask about that yellow M100 Lotus Elan in the background of one of those pictures ;-)
I knew I couldn't have been the only one to notice that.
Car is looking good, NICO. Of course the STi rack bolts right in to the GL10 crossmember (mostly).
NICO
Re: 86 Subaru Leone
Post by NICO »
Legacy777 wrote: Fri May 01, 2020 7:57 pm
we've been around to long now :-D ... some how I found you're brake booster page on my quest to upgrade my single booster, I have no room so I gave up lol
NICO
Re: 86 Subaru Leone
Post by NICO »
lol its my fathers car 1 of to many, but its all stock he fixed it up now its a summer car. he needs to sell all these cars to be honest haha he is restoring a fiat spider at the moment 360 on rotisserie
NICO
Re: 86 Subaru Leone
Post by NICO »
beatersubi wrote: Sat May 09, 2020 5:51 am
yeah my dads lotus all stock tiny turbo lol.
the rack was a pain in the butt but I have a solution for it, so it will be ok one I modify the pinion
