86 Subaru Leone
NICO
Re: 86 Subaru Leone
Post by NICO »
well the sedan is out of storage and ready to get the upgrade steering rack
half of the wagon came home lol, guess its time to install stuff
so we know the motor and transmission fit but this little turbo has a issue, had a feeling this was going to happen but there is a fix :banana:. Borger Warner makes a shorter wastegate and bracket for this very reason
Re: 86 Subaru Leone
Post by entirelyturbo »
Everything looks fantastic, NICO. Keep the updates coming.
*Formerly DerFahrer*
NICO
Re: 86 Subaru Leone
Post by NICO »
DerFahrer wrote: Mon May 11, 2020 3:46 am Everything looks fantastic, NICO. Keep the updates coming.
thank you :D, its moving along now. in 2 weeks I get the intercooler pipes and wiring done then its time to drive
NICO
Re: 86 Subaru Leone
Post by NICO »
my room of mess and my SS made pistons along with pins so there is never rust
NICO
Re: 86 Subaru Leone
Post by NICO »
no more need for the hoist so its time to work outside and finish this wagon
test fit
NICO
Re: 86 Subaru Leone
Post by NICO »
finally found the 5mt trim plastic for the Leone and bonus button that will go with it
also found in Japan new door tops
picked up a factory set of JDM Leone RX floor mats in grey to match my car super rare
got my interior in
NICO
Re: 86 Subaru Leone
Post by NICO »
Goodridge brake lines made up in all SS including the bolts
picked up a set of VOLK RAYS 16x8 ET42 5x100 Wheels so I can put the power down the some bigger rubber 225/45R16
had them sandblasted and they will be white
NICO
Re: 86 Subaru Leone
Post by NICO »
found a original front lip in Japan so it looks like the sedan
was time to take care of the intercooler and like the sedan I got a nice BELL intercooler made up
the bumper plastic isn't bolted up that's why it sits like that or else it will sit straight, I have a brand new skin coming in
NICO
Re: 86 Subaru Leone
Post by NICO »
got the turbo sorted out so the wastegate won't hit the wall
SS feed lines and fittings so never rust
got my PROvent 200 all set up so it can catch all the oil
also add the radiator cap on the radiator like the factory had it so its clean and works flawlessly
2 x 12" opal fans made in Italy, the driver side has a bigger HD motor then the slim passenger side
NICO
Re: 86 Subaru Leone
Post by NICO »
Setrab oil cooler fits so nice ill have to convert the sedan to this model soon
NICO
Re: 86 Subaru Leone
Post by NICO »
these Subarus don't really have a proper toe adjustment so I came up with a heim joint with threads so I can adjust the Alignment much easier, and its all made out of SS so it will never rust
original subaru leone
Version 1 : hard to adjust live on the alignment rack.
Ver II perfection ! ;)
made this long time ago for the bushings in the arms now the wagon will have all pillow ball heim joint ride like the sedan
NICO
Re: 86 Subaru Leone
Post by NICO »
ordered up the aluminum tubes for the intercooler and radiator pipes
first step was get the radiator pipes made up, lower & up pipes for both sedan and wagon
more alignment goodnesses stuff in SS, radial rod fully adjustable for caster & centering the hub under the body of the car.
Re: 86 Subaru Leone
Amazing work as always Nico!!!!!
The SS pistons and dowel pins for the 4 & 2 pot calipers, were those custom made or is there some place I can buy them?
Thanks!
CFK
Re: 86 Subaru Leone
Post by CFK »
Amazing work dude !
Ya I just redid my front 4-pots, would have loved those. Pins were rusted with divots that caused irregular wear.
And I gotta get me that Provent 200 ! :smt103
Build Thread : HERE
92 SS 5MT. Project Daily
84 Jetta Coupe. Real Project
99 A4 Avant. Wife's Daily
