Info on my turbo engine build up
All my base belong to me.
I know, but I didnt want to do that! Wasn't it in this thread that Larry said the same thing, that he went through all the same trouble except spent a good chunk of change on 2.5 heads before realizing they dont fit easy?
BTW thanks for adding the archived messages. Found this thread that should be cross linked.
http://bbs.legacycentral.org/viewtopic.php?t=7755
http://bbs.legacycentral.org/viewtopic.php?t=11624
Yup,
Larry went through all the same thing, and ended up sticking with the 2.2T heads.....that was what I was suggesting you do as well. You didn't want to stick with the 2.2T heads?
no prob.....that was one of threads I definitely wanted to get out there.
Matt Monson
- quasi-mod-o
This is definitely a route you can consider. Cobb's site shows side by side the flow differences of the stock EJ22-T heads and the SOHC EJ25's. If you were to re-work the EJ22's you would want to port the crap out of them. I spoke with the guys at Cobb about this when I first got my Legacy. They said don't bother! They tried it a few years ago and there are just to many things that you would want to change on that 14 year old head design. My thoughts are to go with a 4 year old design like the EJ25's or some EJ205 heads and work with what is required to make it work.
On the flipside, there are a number of guys who have done high power builds with the stock heads. The reality is if your cram enough air through a crappy flowing head like that you will still be able to make power. And 300 hp is not super high power. Sure, that is a lot of power, but it is a whole different realm than 400 or 450 hp....
p.s. Ciper, check PM, there may be more than just the heads available...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
raydadickrs
morgie wrote:after my tests this evening (see engine section).
Ej22t = sohc
ej20t = dohc
ej22t intake != ej20T intake
BUT
ej22t exaust == ej20t exaust (we can use Wrx exaust on our ej22t)
so, we could say
sohc intake != dohc intake
but
sohc exaust == dohc exaust
to be verified, but i hope this helps a little
so are you saying?!?!???
the ej22t will only accept sohc heads
the ej20t will only take doch heads?
the ej22t and ej20t intake manafolds aren't compatable
but the exhausts are?
im planning an ej22t shortblock w/my 98rs top end (heads, intake, exhaust, ecu w/piggyback, and whatever else needed) to try for 300+ whp
anyone know any setbacks to watchout for?
did you read the two links ciper posted that are in the archives?
I highly suggest you take a look at them. Larry has done a lot of work on the heads issue.
He is saying that any engine can take any heads with the right modifications to account for bore and such.the ej22t will only accept sohc heads
Any 2 port exhaust heads can take any other engines 2 port exhaust piping
The ej18 ej25 and ej20 seem to be mostly compatible when it comes to throttle body (some need modification but for the most part they fit). Ej22 and ej22t heads will only work with 2.2 throttle body
Other issues are the coolant piping that runs under the throttle body which I have heard is sometimes an issue (Depending on combination)
Just a quick update.
Since 2.2 rollers with solid roller lifters are hard to find it looks as if hydro rollers are the way to go. Ill end up getting all 16
new lifters from the dealer and O-rings.
Since I take good care of the car and run good oil the hydros should last along time, who knows how most of our cars where taken care of early in life.
Another interesting tidbit is regarding the STI crank in the 2.2t . It seems that the long stroke causes the piston to go lower that the oil squirters. Wether this is enterily bad and if it can be solved with custom pistons remains to be seen. Either way Ive decided to stay with stock configuration in the engine and just replace everything.
Ive also decided to go with gapless rings. A little more expensive but good gains for the money.
Matt Monson
- quasi-mod-o
I apologize if this was mentioned before, but what is your build timeframe?
I know you asked about mine, but I don't remember reading about yours. And thanks for the updates...
Suby Hai!
Suby Hai!
morgie
I'm saying, like Ciper said, that the exaust manifold is the same on the SOHC ej22T and the DOHC Ej20T, but intake manifold is not the same. If you swap the heads, you have to swap the intake manifold too, but you can keep the old exaust manifoldraydadickrs wrote:so are you saying?!?!???
As for my swap / build... i did a first "compatibility check" 2 days ago, and everything seems to be allright, except for the Intercooler Y-Pipe (but that's not a big issue).
Ej22T shortblock + WRX 96 intake manifold, heads (9:1cr is what i've read.. may not require piston swap to keep a good CR once on the 2.2l shortB.), td05, wrx 96 exaust manifold (But is exactly the same as on the ej22t)
morgie
'98 4Runner V6 Manual 4x4.
Matt Monson: The plan keeps getting pushed back. When this project started I had planned to be driving the vehicle in its lowest power form by now.
The engine is already apart and I should have a full price of the machine shop work soon (head flow increase and rebuild).
Ive decided to go with gapless piston rings, from those who I have spoken with this makes a huge difference in turbo cars.
The bottom end of the engine should be done by the end of this month. The heads either this or the next month.
Assembly of the engine wont be far aftewards then I have to drive the receiving car up to Sacramento.
Everything will be installed as stock, including the stock sedan exhaust. One question I have is will the exhaust need an extension since it goes into a wagon?
After installed I will run it for a while to chase any bugs away then schedule an apointment to get the BAR sticker.
Once all the Smog/DMV stuff is completed I will install all of the instramentation.
The next step will most be either
1. Water intercooler installation
2a. engine back exhaust including turbo
2b. turbo back exhaust (headers and turbo later). I already have the parts chosen for the turbo back (in another thread) but Im not sure about the type of turbo I plan to use.
The list goes on but these are the near future milestones
Are there any negatives to gapless rings? I can't think of any other than cost, but maybe there was some durability or breaking-in issue I couldn't figure. I was thinking of going with them in mine.
Got a response from total seal on what to use. The person gave me his direct number so I passed it along to Nate and he is speaking with him for me.
From what I have read this has to be one of the best $ to performance modifications that can be made when inside the engine. It even supposedly helps emissions.
(dangit, typed a long responce and lost it to an error)
My motor is in block prep.
My heads will be picked up mid next week for machine work
2.33 Displ is again a possibility. Nate is prototyping the pistons needed for an STI crank (385$) with EJ20 rods and pistons (custom, correct C/R and pin location).
He forgot to tell me if I got hydro or screw type but rollers are a definate.
mhrallyteam
I have to differ, they are Slightly different. the cast manifold have a different angle on ej20T, I know this since i installed a new stainless up-pipe on my legacy, meant for a WRX. the bolt hole didn't fit by 1/2inch. We then compared my manifold with a wrx one, and noticed the slight angle difference. But if you use the whole manifold assy it should work fine, if you have an up-pipe with a flex.I'm saying, like Ciper said, that the exaust manifold is the same on the SOHC ej22T and the DOHC Ej20T
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
