What would happen....
IronMonkeyL255
Post by IronMonkeyL255 »
It would.
You want the MAF sensor to read all the air going into the engine. If you put the BOV after the MAF, then you are dumping some already measured air. This is the same problem we have with the stock setup.
Rio Red '91 Legacy SS
biggreen96
Post by biggreen96 »
ok cool. sounds good to me. This nasioc thread says the same: http://forums.nasioc.com/forums/showthr ... t=blow+maf
Post by BAC5.2 »
If the BOV is post-maf, then there is no reason to run blow-through.
