YES! Drunken editor wins!!Okay. I guess I could buy that as a definition.
vrg3 wrote:I don't think it would strain the engine more, though, since the engine is still making the same torque. It's just having a different effect in different gears due to the friction's effect being different.
Ah, back to the original question. I don't see why this would effect turbo spool up either unless its because the slower acceleration of the engine gives the turbo more time to catch up. If that's the case, then it makes sense that racers stage with the engine at high rpm to keep the turbo spooling. But then I wonder if that were the case, would peak boost be achieved succesively down the rpm range with each higher gear?But, again, I say -- this definition of "load" shouldn't be relevant to the engine, and it shouldn't affect the boost Matt can reach. Can it?
basically because the more load you put on the motor, the more fuel and the more heat, which makes the air expand which in turn spins the exhaust wheel faster which in turn spins the comp wheel faster, hence creating more boost.evolutionmovement wrote:Damn, what the hell was I writing last night?!'Sippin' on gin and juice. Laid back...'
